masking tape or liquid
Posted by Anonymous on Thursday, November 13, 2003 1:44 PM
im modeling a 1/48 f-18 hornet, i HATE the way my canopy turned out and the rest of the places i masked the paint bleeded through. i use just plain old masking tape, is there a better brand or is liquid the way to go and how do u put the liqid mask in a straight line and stuff
PS. i just started modeling again so explain it well!Smile [:)]
Posted by Anonymous on Thursday, November 13, 2003 2:43 PM
Hey Chris, welcome to the FSM forum. Which version of the F-18 are you building. That is one of my favorite aircraft, I am currently working on the E from Italeri.
I mask canopies with Tamiya masking tape. On this type of canopy I cut it into thin strips and apply them around the edges then I fill in with a liquid masking agent.
On a canopy with several panes I just cut the tape to fit each pane.
This method works if you are airbrushing only. If you are painting with a brush there will always be some bleed through; no matter how well you burnish the tape.
I look forward to seeing some more of your posts in the A/C section.Sign - Welcome [#welcome]
Posted by Anonymous on Thursday, November 13, 2003 5:03 PM
thanks
that explains my problem ive been painting it on with a brush
    May 2003
Posted by qmiester on Thursday, November 13, 2003 7:54 PM
Suggestion: If you are masking over a previously painted color, try painting along the edges of your tape with the bottom color - this will seal the tape and keep the top coat from creeping under the tape - brush on a couple of really thin coats so you won't leave a raised edge when you remove the tape Big Smile [:D]
Quincy
Posted by Anonymous on Saturday, November 15, 2003 1:45 PM
thanks, how do u and wat is burnishing tape
Posted by Anonymous on Tuesday, November 25, 2003 11:50 AM
burnishing is just just rubbing the the edges of the tape down so that you make sure the edges are fully adhered to the model. it is not a form of tape
Posted by Jeeves on Tuesday, November 25, 2003 1:50 PM
toothpicks are the best for burnishing...as they don't scratch the surface of the plastic...
