Primer choice
    August 2008
Primer choice
Posted by NiKe on Monday, August 25, 2008 8:56 PM
Hi there,
I'm building my first model, and all the parts are in medium gray colour.When it comes to priming the surface for painting, I assume the colour of the primer needs to be considered. So then, does it mean a colourless primer like the Tamiya Liquid Primer will not affect the colour of the surface regardless of the colour? I'm using acrylic paint, so do I need a specific type of primer to suit acrylic paints? Your attention appreciated. Wink [;)]
    May 2003
Posted by kirk4010 on Monday, August 25, 2008 10:46 PM
The Tamiya "fine" white that comes in a rattle can works great, drys fast.  While I have not used it, I was under the impression that the liquid primer that you refer to was for fixing scratches and seam repair as opposed to priming an entire model prior to painting.  Other people love Mr. Surfacer thined with laquer thiner and then sprayed.
The art of war is simple enough. Find out where your enemy is. Get at him as soon as you can. Strike him as hard as you can, and keep moving.-Ulysses S. Grant
    June 2008
Posted by EZSnapes on Tuesday, August 26, 2008 12:08 PM
I use Model Master flat white enamel to prime most of the time.  As long as the primer coat is cured, you shouldn't have any trouble using aryclics, lacquers or enamels as the top coat.
Sometimes you might want to prime with something other than white.  Using a darker color, or a complementary color to the top coat, can produce interesting effects.
Al
    January 2003
Posted by Triarius on Tuesday, August 26, 2008 3:05 PM
To find surface defects: Tamiya sky gray XF-19 (acrylic).
Under white: any metallic silver.
Under yellow: white, or silver then white.
Under orange: same as yellow unless you want a slightly darker shade, in which case use a brown.
Under red: same as yellow unless you want a slightly darker shade, in which case use a brown.
The key to using acrylics successfully is to have a CLEAN plastic surface. I suggest washing using Simple Green or Windex, rinsing thoroughly with distilled or deionized water, then wiping down with ethyl, denatured, or 90% isopropyl alcohol just before painting. Once you start painting, don't touch the model with your bare hands.
