Shaken or stirred?
Shaken or stirred?
Posted by Jim Barton on Friday, November 21, 2003 6:54 PM
Of course we're talking paint, not martinis!Smile [:)] With all the posts on these forums, I don't think I ever saw this question discussed: Is it better to stir or shake the paint? I'll let some of you reply, and then in a couple of days (if I don't forget!Wink [;)]), I'll tell you how I prepare the paint. The why of my preparation might surprise a few people.Smile [:)]
"Whaddya mean 'Who's flying the plane?!' Nobody's flying the plane!"
    January 2003
Posted by shermanfreak on Friday, November 21, 2003 8:06 PM
I do both .... first stir, then shake.
Posted by Anonymous on Friday, November 21, 2003 8:12 PM
I like mine stirred and on the rocks! Oh I wasnt talking about martinis ACK! LOL
Seriously I do more shaking than stirring....but I also have BB's in my enamels that save me from doing to much of either!
    January 2003
Posted by Keyworth on Friday, November 21, 2003 9:14 PM
I always stir, but never shake acrylics. too many bubbles that wind up on the model. Enamels don't seem to have the same cohesiveness issues, so I shake the stuffing out of them.
"There's no problem that can't be solved with a suitable application of high explosives"
Posted by berny13 on Saturday, November 22, 2003 9:52 AM
I do the same as Keyworth. I turn the bottle of acrylics up side down for several minutes prior to stiring. This way it has a chance to mix itself. Just remember to turn the bottle right side up prior to opening. Dunce [D)] It sure would make a mess.Oops [oops]
Berny
 Phormer Phantom Phixer
On the bench
    December 2009
Posted by wildwilliam on Sunday, November 23, 2003 9:41 AM
i stir mine.
it gets the pigment up from the bottom and prevents getting paint on the inside of the top.
which helps keep paint out of the threads,
which means my tops never get stuck.
ed.
Posted by David Voss on Sunday, November 23, 2003 10:37 AM
I shake it -- but I guess after reading through this thread I probably shouldn't. Blush [:I]
It just seemed like a pain to sit there and stir a little bottle of paint with a toothpick and then pull it out and have all that paint stuck on the toothpick.
Which then brings me to this question -- are there better things to use than a toothpick? Thinking about the stirring sticks used for 1 gallon buckets of paint, it seems silly to use something narrow and pointed like a toothpick.
I am your attentive pupil. Teach me the proper way. Wink [;)]
David Voss Senior Web Developer Kalmbach Publishing Co. Join me on the FSM Map
Posted by Jim Barton on Sunday, November 23, 2003 12:52 PM
Darn, wildwilliam, you stole my thunder!Smile [:)]Smile [:)] Like you, I like to stir the paint rather than shake it because my experience with shaking the paint goes like this: No matter how tight I put the top on, a tiny bit of paint seeps between the lid and the mouth of the bottle. So I use the paint, put the lid back on, put the bottle away, and the next time I'm ready to use that color, lo and behold, the lid is stuck to the bottle!Angry [:(!] That means I have to get the pliers, which are buried somewhere in the box of carpentry tools at the other end of the living room, buried under hiking books and the paper plates. (Why do I keep the paper plates on top of the toolbox? Trust me, you don't want to know.Smile [:)]) So I have to walk across the living room, remove the paper plates and hiking books from the toolbox and then remove the lid from the toolbox. Somewhere amongst the duct tape, dovetail saw, jars of nails and screws, cans of stain and paint, hammer, screwdrivers, sandpaper and a host of other items is the pair of pliers. So I have to paw through all this stuff, playing a dangerous game called Toolbox Roulette. The object is to lay your hands on the desired tool before the dovetail saw slices your finger off.Smile [:)]
Rather than go through all that, I find that stirring the paint greatly reduces "stuck lid syndrome" almost to the point of non-existence.Cool [8D] That's the main reason why I belong to the stirring school of thought on paint preparation. If you're a "shaker" and have problems with the lids getting stuck, try stirring instead!Smile [:)] You might be pleasantly surprised!Smile [:)]
David Voss will be interested in this: I use the clear plastic greeting card holders as paint stirrers. They look like plastic forks and are available at any florist shop. Snip off and discard the "tines," then cut the card holder into pieces about three inches long or so. (A pair of garden shears does this quickly and easily; wear eye protection.) The long card holders can give you up to six paint stirrers. (A hint: If you cut right, some of the paint stirrers will have a built-in "paddle" that you can use for brand-new bottles or a color that's been sitting around for a long time and needs extra preparation. Use the non-paddled ones for regular paint stirring.) These paint stirrers are wider in diameter than a toothpick. Other choices for paint stirrers: Clean swizzle sticks or chopsticks would also work, as would clean wood barbecue skewers.
Posted by Anonymous on Sunday, November 23, 2003 2:28 PM
i like to stir but i don't buy any stirring stick... i make auto models and when i cut the parts off the plastic, the left over plastic is very thin and is useless after so i just snip those into small parts whenever i need them. very handy and i will never run out of them because when i do run out i'm probably done that model =) and then time for another model.
Posted by Anonymous on Sunday, November 23, 2003 4:03 PM
I also stir my paints but I use my Tamiya stainless steel paint stirrer. They're good for life.Approve [^]
    June 2003
Posted by M1abramsRules on Sunday, November 23, 2003 5:05 PM
definately both. shake then stir. toothpick of course. I have thought of making a stirring tool out of a toy motor, but haven't got around to it. don't know if it would work thought.
    July 2003
Posted by Dwight Ta-ala on Sunday, November 23, 2003 9:38 PM
Shake first. Pop off the cap and stir.
Not on the rocks of course.
    August 2003
Posted by South Aussie on Monday, November 24, 2003 5:32 AM
Apart from Tamyia Acrylics, which I only stir (shaking these leads to Censored [censored]bubbles, which if painting by hand ends up on the Censored [censored]model) I usually shake then stir with a shaped piece of wire attached to an old 12 volt mini drill. To help prevent the paint ending up all over the walls and floor I use a neck from a plastic bottle cut to fit over the paint can or bottle.
Wayne I enjoy getting older, especially when I consider the alternative.
    December 2009
Posted by wildwilliam on Monday, November 24, 2003 6:45 AM
i just stir w/ a thin metal rod, maybe 4 inches long.
i do have one of the Tamiya paint stirs.
somewhere. if it turns up again, i will start using it.
i have used bits of sprue.
i find toothpicks too short to get to the bottom w/o getting my fingers into the jars of paint!
ed.
    June 2003
Posted by M1abramsRules on Monday, November 24, 2003 7:07 AM
that's why it's nice to use Humbrol!
Posted by Jeeves on Monday, November 24, 2003 7:57 AM
I use wood splints (like the kind you used to use in chemistry class) to stir...then use my brush to recapture most of the paint on the stick....
Posted by David Voss on Saturday, November 29, 2003 11:54 AM
Jim Barton, thanks for the tips!
    July 2003
Posted by lizardqing on Saturday, November 29, 2003 3:00 PM
Since I use mainly enamels right now, starting to switch to acrylics, I use the bb in the jar sheking method. I used to shake acrylics and gripe about bubbles why I never thought of stirring them instead I don't know but do now.
