Poor man's gravity feed... sort of
dmk
    September 2008
Posted by dmk on Saturday, November 8, 2008 1:09 PM
 I had to paint a couple small items today (flat black on my P40's instrument panel and dark gray for the tires). Really just needed a couple drops of paint. So I came up with an idea... Cool [8D]
 I put a couple drops of acrylic paint in the pocket of an old foil pill package, a drop of thinner, drop of retarder, and mixed it up with a toothpick. Then I took an eye dropper, sucked up the paint, inverted my Badger 200 airbrush and dropped the paint right in where the bottle plugs in. I sprayed the brush using my middle finger on the button (which was now at the bottom). To clean up, I just sprayed out the remaining paint, squirted some windex in there, wiped around a bit with a Q-tip, then squirted some more windex and sprayed it through the brush until it came out clean. Took longer to write about it...
 Actually found I had a decent amount of control. It surprised me.
 Has anyone else tried this?
    May 2005
Posted by Bgrigg on Saturday, November 8, 2008 8:00 PM
I've heard a couple of people do this. It's a good idea, though one that takes getting used to the trigger being underneath!
So long folks!
Posted by ABARNE on Sunday, November 9, 2008 11:26 PM
I've never quite gone that far, but when I need to paint a very small item, I will thin only a drop or two of paint in my color cup, and hold the airbrush with the trigger on the side.  With the airbrush then working more or less as a side-feed, it sprays up the barest amount of paint.
Andy
dmk
    September 2008
Posted by dmk on Monday, November 10, 2008 8:41 AM
 Bgrigg wrote:
...that takes getting used to the trigger being underneath!
It's actually not that bad. I wouldn't want to do a mottled camo this way, but for just hitting small parts or the inside of the fuselage of a small airplane, it worked pretty well. I'd imagine I could even touch up some camo with practice.
That's a good idea too Andy. I need to try that.
    May 2003
Posted by bud156 on Monday, November 10, 2008 9:06 PM
I wish I would have read this tip yesterday. I spent a few days painting a car body and realized the trunk lid still needed to be painted as it is a seperate piece. Of course I noticed this right after I cleaned up my airbrush after putting the final coat on. Not knowing any better I just brush painted the trunk and it's much darker than the rest of the body. Oh well, I still would have had to re-clean everything, which is the worst part of this hobby (other than those "man, did I screw up" moments).
dmk
    September 2008
Posted by dmk on Monday, November 10, 2008 9:53 PM
Sorry to hear that, but can't say I haven't been there too. If it was me, I'd strip the trunk lid with some Purple Power or Brake Fluid, wash it off really good and paint it again with the airbrush. Maybe I'm just anal, but that would bother me way longer than the hassle of cleaning the airbrush would.
    June 2008
Posted by Hans von Hammer on Wednesday, November 12, 2008 11:33 AM
I do the same thing, DMK... 'Cept I just plug the hole with a piece of duct tape..
dmk
    September 2008
Posted by dmk on Wednesday, November 12, 2008 12:11 PM
So you can turn it over and hold it normally?
 This doesn't interfere with the suction and draw of the paint?
    August 2007
Posted by doc-hm3 on Wednesday, November 12, 2008 1:00 PM
Cool trick, I found that if I wrap the air hose around my forearm a couple of times it helps to control a little better.
All gave some and some gave all.
dmk
    September 2008
Posted by dmk on Wednesday, November 12, 2008 1:09 PM
Good idea. I found the hose was getting in the way when I tried it, so I threw it over my shoulder. I'll try wrapping it around my arm next time.
    June 2008
Posted by Hans von Hammer on Monday, November 17, 2008 11:21 AM
Works fine, you can hold it normal, but you do have to "let it breath" now and again by "popping" the tape open a skosh now and then... You'll know when you need to give it a breath, cuz the paint will stop coming out..
