to prime or not to prime, that is the question
    May 2003
Posted by bud156 on Sunday, November 16, 2008 1:24 PM
I scratch built a taxi cab sign (my first scratch built part, I'm pretty excited) to go on the roof of my model car. I used white plastruct but I'm still going to paint it gloss white. I have grey primer and I'm wondering if I should prime it first, or just paint it as is, seeing as it's already white plastic. Thanks for any help!
    August 2006
Posted by HawkeyeHobbies on Sunday, November 16, 2008 2:00 PM
A light mist of flat white to see if there are any blemishes would be what I would do...you can always use a little water and a polishing stick to wet sand it before you apply your gloss coat.
Gerald "Hawkeye" Voigt
    September 2012
Posted by namrednef on Tuesday, November 18, 2008 9:39 AM
Personally, I have found that most paint troubles I experience occur on unprimed or unwashed plastic.
    December 2003
Posted by hkshooter on Tuesday, November 18, 2008 2:04 PM
Ah, heck. Spray it!
The only time is use primer is to find or hide seam work. OR, if I need to mask where acrylics will be sprayed. Acryls don't stick to plastic worth a hoot.
    February 2004
Posted by RichardI on Tuesday, November 18, 2008 2:14 PM
I prime everything I paint. I use Tamiya rattle can fine surface primer which is a lacquer and fills in small scratches and in general does a great job. Without using your airbrush. It dries fairly quickly, and takes any kind of paint on top, but particularly light colours such as white or yellow. Any metalizers look much better too. So for my My 2 cents [2c] I say yes, prime.
Rich Cool [8D]
On the bench: 1/48 Revell PBY Catalina 0A-10A. Next up: Moebius 1/24 Chariot from Lost in Space.
dmk
    September 2008
Posted by dmk on Tuesday, November 18, 2008 3:42 PM
Does apply primer ever cause problems?  'cause I agree, not priming sure can.
    October 2007
Posted by Milairjunkie on Tuesday, November 18, 2008 7:54 PM
If you were to paint withput primer, white on white, it may not be clear as to how unifrom your coverage is, if you use grey primer you wont have that problem?
