QUOTE: Originally posted by ngc7293`
I am thinking now that I should remount it right at the compressor (using a double sided threaded adapter. That way it would stay vertical and I would have much more hose to work with.
You can connect directly to the compressor if it is real close to the airbrush, but if you have a fairly long hose from the compressor to where you are painting it is much better to connect the moisture trap as close to the airbrush as possible. The reason being that the airhose can collect moisture in it from heat and pass that moisture on to your airbrush. If the moisture trap is connected directly to your airbrush hose then it collects water much better.
Is there anything solid like a workbench that you can mount the regulator/moisture trap to? That is how I had mine before I bought this silent compressor I have now.
They sell brackets similar to this one that the bowl of the regulator sits into:
I made one with a thin piece of 1/4" wood that I bored a hole into and then mounted it under the edge of a workbench with screws and then sat the regulator into the hole in the wood. I hope this helps some.
“Wisdom is the right use of knowledge. To know is not
to be wise. Many men know a great deal, and are all the greater fools
for it. There is no fool so great a fool as a knowing fool. But to know
how to use knowledge is to have wisdom. " Charles Spurgeon
