Badger Velocity vs 100LG
    November 2008
Posted by yuvitz on Monday, December 8, 2008 10:56 AM
Im thinking of purchasing the new badger velocity, my only concern is the fine needle.
maybe the 100LG is a beter all arownd choice.
im using Paasche VL with the no-1 needle, i'd like the new airbrush to be able to draw slightly thinner lines and to be more accurate.
Thanks!
Y.
Posted by Anonymous on Monday, December 8, 2008 3:21 PM
I've wondered the same thing.  The Velocity has a .21mm needle tip combo and the 100LG with the fine tip has an approximate .26mm needle tip combo.  If anyone has tested the two, let us know (MikeV?).
E
Posted by MikeV on Monday, December 8, 2008 7:56 PM
I haven't touched an airbrush is months sorry.
Contact Ken at Badger and ask him.
Kenbadger@aol.com
    May 2003
Posted by DrewH on Monday, December 8, 2008 8:35 PM
I have both. The needles are similar, the tips they use are similar - but a very diffrent break down. For the best fine lines - Velocity, as good for all round work as the 100LG but can get a better fine line imho.
Do yourself a favor and ask Ken. You're paying about the same in the end either way. I did a review on the Velocity here.
Hope this helps you with your decision.
Take this plastic and model it!
