Spraying gloss colors in the cold can be tough but the flat colors don't seem as badly affected. I am in the same predicament as you although you have MUCH colder weather up in the Great White North than we do here in Northern California.
I like to have a 100 watt lamp or bigger and put it close to the paint, model and airbrush to try and warm them up a bit.
If you get them warm you can usually paint, and then take the model into the warm house to dry. I don't know how cold you can get away with this up in Canada but I would imagine when it got below 30 degrees in the garage it would be tough to paint. Not to mention that it is hard to control an airbrush with frozen fingers.
“Wisdom is the right use of knowledge. To know is not
to be wise. Many men know a great deal, and are all the greater fools
for it. There is no fool so great a fool as a knowing fool. But to know
how to use knowledge is to have wisdom. " Charles Spurgeon
