QUOTE: Originally posted by Icehole83
I I know Thayer & Chandler are now made by Badger, but are they higher end... (Like Lexus is to Toyota, Sony to Aiwa) |
The Omni series is manufactured to the best tolerances you can buy from an American made airbrush. The Vega series are just about as good.
I believe the Badger models such as the Anthem and 360 are also comparable to the Omni's quality.
QUOTE: Is the Omni Matrix higher end than the Universal 360? |
I am not sure but I would say the Omni probably has the edge over the 360, but I could be wrong.
QUOTE: And does the Matrix have a Teflon Needle Bearing like the 360 does?
Yes, all of the Omni line have a Teflon needle bearing.
Check here:
http://www.badger-airbrush.com/omni.htm
Another great thing about Badger is that their customer service is second to none!
“Wisdom is the right use of knowledge. To know is not
to be wise. Many men know a great deal, and are all the greater fools
for it. There is no fool so great a fool as a knowing fool. But to know
how to use knowledge is to have wisdom. " Charles Spurgeon
