I just got my Harbor Freight Compressor and was experimenting with the PSI adjustment knob.
Here's the compressor I bought: http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=93657
But the regulator + moisture trap looks much like this: http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXGVA0&P=7
Anyways, I was turning the knob in order to increase the pressure then I heard a "snap/pop" and the knob came off, and now I can't put the knob back on. I thought I broke something, but I've disassembled knob assembly and nothing seems to be missing, snapped, broken, etc. It looks like everything should just go back together no problem, but it doesn't seem to work. The regulator seems to work by compressing or decompressing a spring which is pressed against some "button" which, when pressed, allows air to pass through. Now, the knob isn't "held in place" in order to apply pressure on the spring. It's like trying to swing a baseball bat standing on a turntable...unless your feet are planted against something solid, if you swing your bat, you'll just spin your body. So unless this knob is planted against something solid, it can't apply pressure against the spring, and therefore allow the regulator to work.
Besides the regulator, the compressor seems to work just fine. Does anybody have similar experiences with their regulators? I imagine this is a common issue, given how easily it occurred.
