I own an Iwata HP-BC1P Plus bottom feed dual action airbrush, used it for a 12-18 months, love it, but now i'm ready to throw it out the window.
Background, I have probably built 4-5 models in that time frame, spraying mostly acrylics (tamiya and model master). I have a compressor with moisture catch and normally spray in the 15-20psi range.
So now, my dual action airbrush has gone single action.
For some reason, when i depress the main lever for just air, i get air and paint. I cleaned the needle, nozzle, needle cap and nozzle cap. I normally do that anyways, but did find some minor debris inside the nozzle, removed it and still have the issue, it actually seems worse now.
Not sure what to do now, any thoughts?
Thanks for the help if you do,
Paintchips
