Paint Cracking Problem
    July 2006
Posted by Dick McC2 on Tuesday, January 27, 2009 6:10 AM
I am in the process of building up a F-86F Sabre and plan on putting down various shades of Alclad II metallic paints on it. I first airbrushed a coat of Model Master 36270 gray as a primer coat, using Testors airbrush thinner. I let that dry for 24 hrs, and then applied a coat of Model Master Gloss Black. I let that dry for 24 hrs and yesterday got ready to apply a second coat when I noticed a couple places where the paint has cracked, small cracks and wrinkles to be sure but would definitely be noticeable should I apply Alclad without sanding. I haven't run into this problem before, but am guessing that I thinned the Gloss Black too much. Anyone have any ideas? I plan on letting the Gloss Black thoroughly dry, probably about a week, and then sand out the cracks and wrinkles with 2400 to 12000 sanding pads before attempting to put down another coat of Gloss Black.
Thanks in advance,
Dick McC
    August 2005
Posted by Phil_H on Tuesday, January 27, 2009 8:50 PM
You're talking about cracking with the appearance of a dry lake bed/crocodile skin?
There can be a number of reasons for this happening.
  • surface contaminants preventing your primer coat from adhering properly - shrinkage on application of your top coat pulls primer away from surface.
  • insufficuent drying time for your primer coat before top coating - shrinkage over a "soft" undercoat cauese cracking
  • too thick a top coat, causing uneven drying between the top and bottom layers of paint.
  • forced drying causing the top layers of paint to dry faster than the lower layers
  • ambient temperature too hot/cold causing uneven drying.
I'd sggest spraying in very light mist coats and allowing to dry thoroughly before recoating.
