Dark Spots
    February 2009
Dark Spots
Posted by felipejcg on Tuesday, February 24, 2009 1:28 PM
When my tamiya acrilics light gray drys of im getting spots of darker gray in some areas. Why is this? I havent mixed the paints with any other colors. I did thin it, is it because its to thined out?
    January 2003
Posted by Triarius on Tuesday, February 24, 2009 2:27 PM
Sounds like pigment separation. This can happen if you dilute the paint too much, or if you let it sit in the cup too long, sometimes even while spraying. This is a particular problem with colors containing white pigments like grays.
Tamiya acrylics should be thinned ~40 to 50% with either Tamiya thinner or 90+% isopropyl alcohol—about the consistency of 2% milk. Don't thin in the cup. Thin in a separate container.
