Model Masters Enamel ?'s Hardener?
    March 2009
Posted by Sproket on Sunday, March 1, 2009 12:42 PM
Im painting a canopy and it has been 2 days since I applied my base coat of white which was over primer.
Can I sand the enamel base coat? I do see a small piece of lint.
Im going to apply another coat of base as well. Can these model master enamels be sanded? They feel hard when dry but if I leave my finger on it to long it gets tacky.
The model master white base enamel is from a spray can. I will airbrush the rest.
Thanks
    December 2003
Posted by hkshooter on Sunday, March 1, 2009 10:03 PM
Gloss or flat. Gloss, I'd let it set a week. Flat, you can sand it in an hour.
    March 2009
Posted by Sproket on Sunday, March 1, 2009 10:58 PM
it doesnt say if it is gloss or flat. Its MM spray can bright white. it says I can recoat after 3 hours or 48 hours. It looks like a semi gloss
Posted by MikeV on Monday, March 2, 2009 3:56 AM
What is the temperature where you sprayed it and where it is drying?
If it is too cold it can take a long time to dry.
Move it to the warmest place possible and if you sprayed it very thick expect it to take a lot longer to dry.
    March 2009
Posted by Sproket on Monday, March 2, 2009 12:07 PM
The spray can says MM enamel #2943 Bright white.
I live in AZ and very dry here. Its 75 degree during day and colder 70 at night in the room. The canopy is in a room that get no air blown into it, so its in a low dust place.
I really like the colors MM has for enamels.
 Is there a hardner I can use to mix with before I spray the enamel?? Do you have a name?
Thanks
