Acrylic or Enamel???
Posted by Anonymous on Friday, December 5, 2003 9:56 AM
I have a very generic question here for everyone. I’m new to armor modeling but have been modeling for many years in various subjects (fixed wing aircraft, F1/auto, rotary aircraft). I have read many posts that mention the use of Acrylic paints on armor kits. I have always been a big enamel painter and I am curious if there is a reason or reasons for the use of acrylics in this particular subject? Is it trends, ease of use, doesn't really matter? I’m really getting into the armor kits and may make it my main subject of interest. I guess if there is something I’m missing by not using acrylic paints PLEASE let me know. I’m open to using any medium.
Thanks for everyone’s input!
Posted by Anonymous on Friday, December 5, 2003 10:13 AM
Justin,
It is more a matter of preference I suppose. But here is why I use acrylics.
- Fast. I can spray a whole 3 color camo job in one day (less the weathering). It can be masked fairly quickly after spraying. I used silly putty to mask, it has little or no tack so there isn't much chance of lifting the paint.
-Clean. Thin with water/alcohol/flow aid mix and your ready to go. I can flush out my airbrush between colors with tap water and be ready to go again.
-I can use oil washes over it without any chance of damaging the base colors. Also I can scratch up paint coats (weathering) easily because it isn't as hard as enamel.
There is some concern that acrylics don't airbrush as well, but using flow aid really helps this a lot. One thing to watch out for though is this.... Testors Dullcoat and Glosscoat react badly with Tamiya paints. I haven't had this problem with other acrylic paints. This is also outlined in an article in FSM from several years ago.
God Bless
Kenneth
Posted by Anonymous on Friday, December 5, 2003 10:14 AM
I use acrylics (Tamiya) because of the kind of 'clear' I use. I use a lacquer 'clear-coat' that I started using while building car kits. Anyway, Tamiya acrylics are not bothered by the lacquer 'clear-coat'. The two are compatible! Enamels would be another story. I also find acrylics seem to dry faster. Use whatever works for you.
Glenn
    May 2003
Posted by styrene on Friday, December 5, 2003 10:43 AM
Speaking very relatively, acrylics (depending on manufacturer and thinners used) can be safer to use than enamels. The solvents aren't quite as volatile; therefore, the potential for overexposures to solvent vapors via inhalation is reduced. However, the use of isopropyl or methy alcohol-based thinners raises the risk substantially. Acrylics may also potentially reduce the risk of fire. Once again, the choice of thinner material may increase that risk as well.
Gip Winecoff
Posted by Anonymous on Friday, December 5, 2003 10:44 AM
After being a DIE HARD enamel user for years, I made the switch to acrylics. (Tamiya to be specific) I can get better flow and results with them, in my airbrush. Not to mention, cleanup is sooooo much easier.
The only thing is, with the tendency acrylics have to dry rather quickly, I still use Testor's Model Master enamels for weathering and drybrushing. Enamels give me a longer working time.
Posted by tigerman on Friday, December 5, 2003 7:28 PM
Not much to add except that I prefer airbrushing Acrylics and brushing on enamels. my My 2 cents [2c]
 Eric
    January 2003
Posted by shermanfreak on Friday, December 5, 2003 8:14 PM
I've been a diehard Tamiya Acrylic fan for a number of years. Mostly because I don't like the clean-up of enamels.
Posted by Spamicus on Friday, December 5, 2003 10:21 PM
I use both, but I tend to use Model Master acrylics more. I'm a little lazy and clean up is much easier. LIke Eric said though, brushing with enamels is easier.
Steve
    July 2003
Posted by Stormbringer on Saturday, December 6, 2003 3:54 AM
As I have nowhere to use an airbrush I tend to stick to Humbrol enamels as I've never had any success brushing Tamiya acrylics.
Regards
Pete
Nolus Illegitemi Carborundum Keep the Pound! Down with the EEC and the Euro
    August 2003
Posted by South Aussie on Sunday, December 7, 2003 12:10 AM
jmixon as you can see it is realy a matter of personal choice whether you use acrylics or enamels. I have used both for airbrushing but usually use enamels for brushing but I am in the process of converting to using Vallejo Acrylics.
One big advantage of acrylics is the after painting clean up. On thing I did learn about brushing with Tamiya Acrylics is that you have to let then not only to dry between coats but allow the acrylic to cure -Sleepy [|)] this can take up to 72 hoursSleepy [|)] failure to do this will cause the previous coat to disovle as you are brushing.
Wayne I enjoy getting older, especially when I consider the alternative.
Posted by Anonymous on Monday, December 8, 2003 10:32 AM
Thanks for everyones input.
I did use some MM acrylics this weekend and had great results considering its my first time using them. I didn't have to thin and cleanup was a snap. I did have a little spatter or overspray with them but nothing to be worried about. I believe if I thinned them out a little bit that would help quite a bit. I was actually using a wide spray needle in my brush so that could have contributed a little.
Needless to say I think Im hooked. Another good thing I noticed at least here locally is that they are a little cheaper than enamel paints. Not much but any savings is better than none!.
Thanks for the input South Aussie...I did notice that happen this weekend. I preshaded with black then waited about 15 min then sprayed a base color and it all blended together on the particular piece I was painting. Actually I got lucky and it made the color more what I wanted but this is very good information.
Posted by Anonymous on Friday, December 12, 2003 4:14 PM
    July 2003
Posted by MonsterZero on Friday, December 12, 2003 5:08 PM
I think acrylic paints win for most applications . However, they may take a few weeks to cure 100%. They're fine to the touch and recoating in less than an hour but don't touch with bare hands! Put on thin white cotton gloves, fingers will leave nasty greasy prints, esp. visible on matte surfaces.
Posted by cassibill on Friday, December 12, 2003 5:40 PM
QUOTE: Originally posted by kurlannaiskos
Sign - Welcome [#welcome] (<-the only artifact I still need for the Unlimited Set btw.)
Hello fellow trekkie did we scare you off or did another one of your inter voices gain control and back out? We're all crazy and all are wecomed.The Chase is probably one of the funiest episodes of TNG. "It could just be a recipe for biscuits for all we know,"Gul Macet. Naduq" In that case I'll send you my mother's" Just jump in.
cdw My life flashes before my eyes and it mostly my life flashing before my eyes!!!Big Smile The 1/144 scale census and message board: http://144scalelist.freewebpage.org/index.html
Posted by Anonymous on Sunday, December 14, 2003 3:26 AM
It sems that all the airbrush users prefer acrylics but if you are brush painting you will find that enamels give much better coverage, especially the lighter shades.
    December 2003
Posted by 9x19mm on Sunday, December 14, 2003 6:34 AM
I almost made the switch to acrylic today, but while I was at the hobby store looking at paint I noticed that it seemed sickly compared to the same brand enamel. The color was model master medium green. I didnt stir the paint but opened the lid on both and it didnt seem like they were the same color. I showed the employee and asking him to verify, and his response seemed to be thats the way it is. Anyone else seem to notice this or just bad batch/mismarked?
Posted by Anonymous on Sunday, December 14, 2003 3:19 PM
Replying to 9x19mm - comparing enamels to acrylics, unshaken, in the bottle, is like comparing apples to oranges. The chemistry of the two is different. The pigment in acrylic paint will almost entirely settle out after sitting. If you look at the pigment in the bottom of an acrylic paint, medium green, for instance, the pigment is a very dark green and the diluent or liquid, is a blue color. So you cannot compare the two until a coat of the paint has been laid and completely dried. You are better off comparing the color chips on the paint racks in the store.
Posted by Anonymous on Monday, December 15, 2003 6:34 AM
BUILD TO LIVE, LIVE TO BUILD!
ENAMEL
[img=left]http://www.geocities.com/veritasps02/f86f-paf.jpg[/img=left]
vote---
http://www.hbo.com/boxing/games/
for Mr.Pacquiao!
Posted by MikeV on Monday, December 15, 2003 8:41 AM
I have yet to try acrylics on plastic models and have only used Model Master enamels thus far. I am going to try acrylics to see if I like them soon as spraying enamels in the garage with no paint booth is a pain.
The only negative about acrylics, at least all of the ones I have used or heard of, is their inability to take masking without an overcoat of clear. Acrylics by nature do not have a chemical that will etch the plastic and provide good adhesion as you get with paints like lacquers, urethanes and enamels. This is why automotive airbrush artists use mainly urethanes as their adhesion is fantastic. They are chosen for durability also which would not be a factor for a plastic model paint job, unless you plan on leaving it out in the rain. Big Smile [:D]
Posted by Anonymous on Monday, December 15, 2003 9:32 AM
Depends what I'm doing. Acrylics for figures, landscape etc because they dry fast, are easy to blend, mix and shade.
I use enamels for 'hardware' for exactly the same reason. Enamel colours tend to be stronger an more vivid and don't seem to be as 'organic' as acrylics.
Posted by Anonymous on Friday, January 16, 2004 4:54 AM
As in south africa tamiiya acrilic is the main brand I have found that the colors do not spray on as even as enamals.I used jap green on a plane and found the tone varied to such a degree that the plane appeared patchy.Same happend on a tank,dispite further coatings.I will stick to enamels.Harry
    January 2004
Posted by keeg on Wednesday, January 21, 2004 6:19 PM
Wow, my head is swimming. A lot of good information and it seems both paints have pros and cons.
Question:
Should you use a primer like "Poly S Plastic Prep" , which Mike mentioned in another post, before you apply acrylic paints or any paint? Also, has anyone tried the acrylic paints like they use for ceramics or crafts? You know the kind you can pick up at Wal-Mart or are they totally different?
Thanks Thumbs Up [tup]
Posted by MikeV on Thursday, January 22, 2004 7:02 AM
Keeg,
The Poly S Plastic Prep I mentioned is NOT a primer, it is a cleaning solution that you wipe the plastic with to remove oils, fingerprints, and static.
You let it air dry and then you can airbrush the model.
A coat of primer after the Plastic prep would be a good idea to reveal any flaws in your work and to give the paint a little more tooth to adhere to.
Those other paints you mentioned I am not familiar with, but I have heard a few people using them with some success. Most water-based acrylics like that were designed for textile and craft uses and usually do not adhere really well to hard surfaces, although some may. If you are not going to mask over them then they may work fine.
    January 2004
Posted by keeg on Thursday, January 22, 2004 11:35 AM
Hey Mike,
Thanks for the reply, and from reading other post in this forum may I say you seem very diligent in helping people like me out and I for one appreciate it. Ok enough of the warm and fuzzy Censored [censored].
So would there be any advantage of using the Poly S Plastic Prep over Dish soap and water? One thing I’m thinking is water contaminate residue like minerals. I feel I’m going a little overboard with the question but to me and other things I do prep is an important thing. “Measure twice, cut once”
Also, after a coat of primer and you do find a flaw, are there any best practices to repair it? I mean do you just put the putty right over the primer? This may be to general of a question and also covered in another location.
If you couldn’t tell I don’t know much about all this and I’m dieing to start working on two models I purchased two weeks ago but I don’t want to rush into them and make it a disaster.
Thanks for the help in advance. Thumbs Up [tup]
Posted by Anonymous on Thursday, January 22, 2004 12:25 PM
I use Acrylic, primarily, because I live in a small apartment.
If there is a need to handbrush, then I will use enamels.
Posted by cassibill on Thursday, January 22, 2004 12:34 PM
keeg:I use Walmart Acrylics on ground work but I haven't tried it on a model. Might try to use them to blend my figs. into the ground work.
    January 2004
Posted by keeg on Thursday, January 22, 2004 4:34 PM
Thanks cassibill,
I need to check on the brand name, but I'm sure there was an acrylic paint at Wal-Mart that said it was for smooth hard surfaces. I was thinking of giving some of them a try. If they work, they are much cheaper than what you will pick up at the hobby store. Also you may have to blend the colors together to get color you want. And If they don’t work, like you said, they would be good for the ground work.
Posted by MikeV on Thursday, January 22, 2004 5:06 PM
QUOTE: Originally posted by keeg
Hey Mike,
I'm glad to be able to help if I can, as are all of the other great modelers here. Wink [;)]
QUOTE: So would there be any advantage of using the Poly S Plastic Prep over Dish soap and water?
Probably not. Some people use isopropyl rubbing alcohol also as it does a good job of cleaning oils and dirt and you don't have to risk getting water in somewhere that you don't want it. Wink [;)]
I am not positive but I believe you can just put putty right over the primer and it will work.
Correct me if I'm wrong guys. Confused [%-)]
I have never done any priming and repairing so I am unsure.
    January 2004
Posted by keeg on Saturday, January 24, 2004 10:55 AM
Thanks Mike Thumbs Up [tup]
    November 2003
Posted by roosterfish on Sunday, January 25, 2004 2:24 PM
I'm a rare enamel paint fan. I've tried to use acrylic paints but I didn't like the coverage that I got out of enamel. My enamel paints seems, after an air brush session, to smooth over and stick better. While I agree it is easier to clean acrylic paints out of an air brush I found that eventually there would be an acrylic paint build up in the brush. I almost cried when I had to do a through cleaning to get the acrylic binder off the air brush parts. There were small acrylic bits that could clog the small and expensive air brush parts. I'm very through about having a clean and well-maintained air brush. With enamel paints I like being able to spray or wipe solvent through the air brush and have it easily come clean.
I've used enamels forever and got used to their painting properties and quirks. They 'stick' better on models and are softer than the hard shell acrylic paints. Softer enamel paint is good for me as the more resilient paint will absorb inevitable bumps that a model gets with out chipping off like hard shell acrylics would.
I think I'm going to be an amateur enamel painter forever.
Winners never quit; quitters never win.
