QUOTE: Originally posted by kansan
The ad in FSM (my most favorite magazine) makes reference to a single nozzle design (one nozzel for EVERYTHING). Does this infer that you can adjust for different patterns and coverage? |
It means that the airbrush can spray fine lines and thicker lines with the same needle/nozzle combination it comes with. It just depends on how far back you pull the trigger on the airbrush.
QUOTE: Secondly, does the unit come with both siphon and gravity feeds. I am in to 1/72 and perfer the gravity feed if for no other reason than to conserve paint. |
Except for the Badger 360 and the Omni Matrix, all other airbrushes are either gravity-feed or siphon-feed, not both.
The Anthem is a siphon-feed airbrush.
If you prefer a gravity-feed only then I would suggest the T&C (Badger) Omni 4000 or Iwata Eclipse CS.
![](http://img.photobucket.com/albums/v207/MikeV/225px-MALS-26.png)
“Wisdom is the right use of knowledge. To know is not
to be wise. Many men know a great deal, and are all the greater fools
for it. There is no fool so great a fool as a knowing fool. But to know
how to use knowledge is to have wisdom. " Charles Spurgeon
