Paint mixing ratios
Paint mixing ratios
Posted by ipms40049 on Saturday, December 20, 2003 7:11 AM
Pardon my stupity, but when mixing paint, when one says, "one part paint, to so many parts thinner", how is the one part, or two or three etc etc, measured? with a pippett? or what. and do you mark a line on the pippett or dropper your using to know where to fill it up to with the paint or thinner?
Thanks everyone!!
Pat Hensley Booneville, Ms "Thank you for being here and playing nice"...please do not drag sand outside the box ! CURRENT BUILD(s) Revell 1/72 U Boat VII C Tamiya Willys Jeep - for 2010 Nats Bronco's Staghound -for 2010 Nats Dragons M16 Multi gun carriage - for the 2020 Nats. LOL
Posted by MikeV on Saturday, December 20, 2003 10:07 AM
I use eye droppers from the drug store and just eyeball it.
Fill up the eyedropper to the same point each time with paint and then use another eye dropper for the thinner. It doesn't have to be perfectly the same each time as long as it is close. Wink [;)]
Posted by Anonymous on Saturday, December 20, 2003 10:17 AM
i don't really measure, I just dump it in and then adjust the other for what I did with the first one, so far so good.
    July 2003
Posted by saltydog on Saturday, December 20, 2003 8:32 PM
i take a pippet and count the drops as i gently squeeze. if im mixing a whole 1/2 once bottle or so, i take a tape measure and permanant marker and measure the hieght of the container to the point of where the container begins to get narrower. i then make tick marks on the side of the container according to the ratio i want. if you want 2 parts paint and 1 part thinner divide the hgt of the jar by three and make your tick marks. after a few times with the same container and ratio, just do like the dude above and just eye ball it.
Chris The Origins of Murphy's Law: "In the begginning there was nothing, and it exploded."!!! _________ chris
    January 2003
Posted by plasticmod992 on Sunday, December 21, 2003 5:11 PM
Your question is exactly how I measure the paint for the ratios. I use glass eyedroppers instead of plastic pipetts, mark the amout of paint on the eye dropper with a marker...etc. You've already got the idea, give it a shot. To clean my glass eye droppers I simply swish them in mineral spirits or laquer thinner and your done.
Greg Williams Owner/ Manager Modern Hobbies LLC Indianapolis, IN. IPMS #44084
Posted by Anonymous on Sunday, December 21, 2003 5:37 PM
For small amounts pippette and mix in a small metal bowl.
For large amounts I get the Spare bottles from Tamiya/Gunze that have the measurement markers on the side, this way I can store the paint for a long time. Just need to restir the paint and am ready to go.
For even larger amounts I use plastic measruing cups that are used to measure liquids for casting/molding.
Posted by MikeV on Sunday, December 21, 2003 5:57 PM
Same here Greg, but I also remove the rubber bulb off the end and run a Q-tip down the eyedropper to clean the paint in there and sometimes I find it necessary to run a pipe cleaner soaked in thinner down through the opening to get that clean.
    January 2003
Posted by plasticmod992 on Tuesday, December 23, 2003 12:42 PM
We are on the same sheet of music indeed MikeV....exactly the same here. You beat me to the punch as ususal! Big Smile [:D]
    September 2003
Posted by checkmateking02 on Thursday, December 25, 2003 1:22 PM
I use measuring spoons (liberated from the kitchen; my wife hasn't missed them). Some are as small as 1/8 teaspoon. Metal ones are good if you can find them; they clean up with Dio-Sol. A strong thinner might melt/distort plastic ones.
Posted by Anonymous on Monday, December 29, 2003 11:20 PM
Paint mixing ratios are relative proportions. Therefore, if you are mixing 2 parts reducer to 1 part paint, then your parts must be consistent. In other words 2 drops reducer to 1 drop paint, or 2 cups reducer to 1 cup paint, etc. The other guys have it right too. Just remember that the proportions must always be consistent. BT
