For the propeller I would use a piece of plasic card to cover the back area of the engine to hold the shaft in place. Trim it to cover just the area needed and glue it in place.
For raised lines there are many ways to accent them:
1. Preshade like recessed lines but when you put finish coats on spray from one direction only to create a shadow.
2. Preshade with black then paint normally. After paint has dried use fine sanding stick to sand top layers of paint off the raised area to expose the underlying color - takes some skill and practice to do this.
3. Use a Micron pen or artist pencil to trace the lines after final painting.
4. Wash with sludge wash then wipe carefully in one direction only with slightly damp paper towel.
