First Airbrush
First Airbrush
Posted by Anonymous on Wednesday, December 24, 2003 10:12 AM
What would you suggest for a persons first airbrush? I don't need something to fancy or extra precise. I just need something that will get the job done. For a reasonable price of course.
Posted by Anonymous on Wednesday, December 24, 2003 11:06 AM
Many will recommend as a simple, inexpensive brush like the Badger 350 or the Pasche H. I hated mine (I've had both) but i've seen many people get good results. I tend to recommend the expensive route. I've owned a lot of airbrushes and my Iwata HP-CS is far above the others in all respects (ease of use, ease of cleaning and quality) It costs quite a bit more but if you ever plan to buy another brush down the road, it makes more sense to spend the money only once. I comes down to your budget and needs.
Posted by Anonymous on Thursday, December 25, 2003 10:53 AM
I just bought the tamiya spray-works compressor + air brush too, I need to find a 7.2 volt converter for it though :(.
I bought a perfect grade wing zero custom Gundam model to try it out on...
AFTER i put together a few models with the air brush :P
this is my first air brush after about 10 years of off and on modelling.
    November 2003
Posted by shrikes on Thursday, December 25, 2003 11:01 AM
Instead of starting a new topic and cluttering up the forum, i decided to just ask my questions in this thread. At least it's more or less the same question as Trekkie's.
Okay, i now have saved enough to buy myself an airbrush and compressor... And i wanted to know what kind of airbrush i should be buying -- single action or double action, gravity feed or siphon feed, etc... What should i be looking for in an airbrush? I really don't need the brand just yet because there are critiques of those in the sticky Airbrush FAQ. I've never owned one and this is going to be a big investment, so i don't want to muck it up. I was also thinking about buying the Tamiya sprayworks set and then buying one of the high-grade airbrushes... am i making a mistake? comments? Smile [:)]
Blackadder: This plan's as cunning as a fox that used to be Professor of cunning at Oxford University but has now moved on and is working with the U.N at the high commission of cunning planning
    November 2003
Posted by roosterfish on Thursday, December 25, 2003 12:17 PM
Nornicle...motors (compressors), by nature, will take a wide variation of voltage. A 9-Volt power supply will work. Excess voltage is absorbed by a little more speed of the motor and a little more heat. Not enough heat to effect the compressor life since compressors live in heat...like a cat?
Winners never quit; quitters never win.
    January 2003
Posted by shermanfreak on Thursday, December 25, 2003 12:19 PM
Trekkie & Shrikes - first of all you need to define in your own minds what you want your airbrush to do not only right now but in the concievable future. What's the smallest scale you're going to work in? Are you going to attempt tight camo patterns? If you work in small scale ie 1/72, or wish to attempt type camo patterns, then you will probably need a dual action airbrush. If you work in 1/35 or larger and don't do too intricate a camo pattern, then a single action would be just fine.
I've used a Paasche H for many years now ... and it's still all I'll ever need.
nornicle - Your first post !!!! Welcome to the forums !!!!
Posted by MikeV on Thursday, December 25, 2003 12:56 PM
I agree with Shermanfreak.
If you can answer the questions he asked then it will be easier to suggest a certain airbrush for your needs.
Also, how much are you willing to spend as this will determine also the airbrush and compressor you get.
No offense to anyone who owns one, but the Tamiya Spray-Works is not something I would buy as it is nothing more than a single-action airbrush with little control. It also has airflow the entire time it's running which I think is strange.
Posted by Anonymous on Friday, December 26, 2003 8:24 AM
Mike V has an important point regarding the lack of control. I can't even imagine not having a double action. The initial concept may be intimidating but once you use one, you can't imagine going back. Even if I'm only going to spray a square centimeter, I'll still break out my HP-CS. I find it's easier to clean than the Pasche H and Badger 350 (and every other brush I've owned.)
Posted by Anonymous on Sunday, December 28, 2003 7:15 PM
I am new in modeling and just got my first airbrush, a Paasche VL. It was relatively inexpensive on eBay ( I think about $65 to $75.) One of the things I like about it is that, although it is a double-action model it can be set to operate in a single-action mode. So far it has worked well for me, doing single-color armor. The hard part is getting the dilution right for the various paints.
I am running it off of a small Campbell-Hausfield air compressor. This isn't a big one with a tank, but one of the smaller units that is used to air up tires and toys, etc. It seems to work fine so far, despite what others have said. Again, I haven't done anything complex yet. It does have the capability to vary the air pressure, although it is difficult to regulate well. It is also really, really, loud. It is less expensive than a true airbrush compressor and the multiple uses makes it easier to justify.
Posted by Anonymous on Monday, December 29, 2003 7:29 AM
jcheyney, I hate to bring this up but dixieart has brand new Pasche VL with free shipping for $59. Gotta watch out on ebay!
Posted by Anonymous on Monday, December 29, 2003 8:17 AM
Sign - Ditto [#ditto]
Ebay has some good bargains then....well they make you pay for something that with a lil shopping and reading around you could find cheaper elsewhere.
I am by no means an Airbrush expert, but let me add my My 2 cents [2c]...
I have 2 Airbrushes, and since this past saturday 2 compressors.
I have a Paasche VL
and an Omni 4000G.
The Paasche VL is good, not great but not bad either. It's down fall is the seemingly pain in the rear cleaning it requires. Its not hard, but just takes some work on how to do it thoroughly and quickly. Changing colors isn't exactly easyily done either and the airbrush requires some cleaning before moving on to another color. I've found if you skip the cleanup in between your old color and your new you WILL wind up with a nice blend of the 2 on your model at some point. Theres lots of places for that paint to hide on the inside of the VL.
The Omni well I used it once last week mainly to do some testing with so I wont post any comments about it just yet. All I can say so far is cleanup is a lot easier and so is color changing than with the VL
    November 2003
Posted by shrikes on Monday, December 29, 2003 8:57 AM
Oh, and another thing... what do you mean when you say internal and external mix? is this even an airbrush term (i think i've heard it around...)?
Posted by Anonymous on Monday, December 29, 2003 9:04 AM
on a internal mix airbrush the paint is introduced into the airflow inside the airbrush and come out as a single stream. External mix is the opposite where the air nozzle blows air over the point where the paint is released, outside of the body of the airbrush.
    November 2003
Posted by shrikes on Monday, December 29, 2003 9:26 AM
So it is a real term... *phew!* So what are the advantages of one over the other? does one spray a bit more evenly than the other, or maybe one is harder to clean than the other?
Posted by Anonymous on Monday, December 29, 2003 10:02 AM
many claim that external mix brushes are easier to clean but I've had badger 350 and Pasche H and my Iwata HP-CS is far easier to clean. I'll leave the quality opinion to someone else as I hated my H and 350 so I'm too biased. My Iwata is near perfect.
Posted by Anonymous on Monday, December 29, 2003 3:50 PM
I don't know much about the best airbrush to get but if you are looking for a place to get a certain airbrush really cheap I suggest:
www.bearair.com
The website is really badly made and there are no pictures or info on the products but if you know what airbrush you want you can usually get it alot cheaper then normal. I got my Paasche H there for 41 dollars and it usaully costs around 60. By the way may Paasche H works great for my modelling needs and its easy to clean.
Posted by MikeV on Monday, December 29, 2003 4:02 PM
I suggest Coast Airbrush, Dixie Art, and BearAir all as great places to buy.
If you want a place that helps you out better than anyone else then go with Coast Airbrush. http://coastairbrush.com/
Dave and his staff have forgotten more about airbrushes than most of us will ever know. Wink [;)]
Their prices are competitive on most airbrushes and accessories too.
Posted by Anonymous on Monday, December 29, 2003 7:52 PM
$65 to $75 seems pretty pricey, Sad [:(] but it's a good brush. Only $60 complete from dixie art and $45 for the card set shipping included.
I still use a "small" 1/2HP! Campbell - Hausfield compressor, but I have an air tank with a water trap and regulator. Works real well in terms of air supply but it's a pain to pump up. You can go to Wally's and get a tank real cheap, then you will have very good control on the air, no more pulses and no noise while brushing.
    November 2003
Posted by shrikes on Tuesday, December 30, 2003 3:53 AM
I checked some local stores for airbrushes, and i found a badger 150 for a little over $120. I'm paying too much, right? is the 150 any good?
Posted by Anonymous on Tuesday, December 30, 2003 5:06 AM
Hard to say how much you should pay since you are in the Philippines. It's definitely a lot more than what you would pay in the States. Maybe you can look for an Iwata Eclipse and compare prices. The Badger 150 is a good brush, but I think the Badger Anthem would be better for model builders. One tip does all the different spray patterns instead of having to change tips and needles for the Badger 150.
I just got 2 new airbrushes within the last two weeks, a Badger 360 and an Iwata Eclipse SBS. In fact the Iwata arrive in the mail about 10 hours ago. Haven't used it yet, but these two brushes seem to have very similar designs, except for the feed which is unique on the Badger. The Eclipse feels a lot heavier. So far I really like the 360. I'll do some comparison when I test the Eclipse out. The Badger 360 seems to be a little less complicated to disassemble.
I also have a loaner Paasche VL in the box. I'll do some comparison when I get the time to try them out.
Posted by Anonymous on Tuesday, December 30, 2003 9:58 AM
I think that's too expensive, shrikes. But I guess it really cost that much there in the Philippines. I got a Badger Crescendo 175 complete set for about $70.
Anyway regarding your queries about airbrushes, maybe you should grab a copy of the January Issue of FSM, if you still don't have it. They have an article about selecting an airbrush in this issue.
Posted by Anonymous on Tuesday, December 30, 2003 1:07 PM
In the Jan issue they reviewed Single Action brushes, and in the next issue they plan on reviewing double actions...
Now in addition to my above post, some people prefer single over double and vice versa. I have only ever had a double action, my first airbrush was Double Action(Paasche VL), and thats all I care for. Some people who start off on single actions have a harder time learning double actions(though to be honest its not hard)so I would recommend starting off with a double action. In the long run I think a double action provides more over all control versus a single action. Of course this is just my opinion, they both have thier uses and advantages as well as dis-advantages.
    January 2003
Posted by plasticmod992 on Wednesday, December 31, 2003 6:13 PM
I would simply recommend an Iwata Revolution Hp-CR available from www.dixieart.com. The Revolution Hp-CR is a double -action, gravity -feed airbrush featuring a .5mm nozzle(great for some detail and large area coverage). This airbrush is very inexpensive for an Iwata at a cost of only 59.00 at the Dixe Art site. The internal parts are minimal, break-down is easy, cleaning is very-very easy due to it's gravity feed design. This airbrush sprays anything from acrylics to laquers with no problems. The internal needle bearings and such are solvent proof so theres no worries when using your favorite media. I own and use the Revolution HP-CR for detail and general use on my 1/72nd scale modern jet models for some detail & single colors. I use an Iwata Hp-C for camo out-lining & weathering techniques. Good luck with your choice!
Greg Williams Owner/ Manager Modern Hobbies LLC Indianapolis, IN. IPMS #44084
Posted by Anonymous on Thursday, January 1, 2004 4:58 PM
I just got my Badger Anthem set (155-7) on Ebay for $50, whereas the Badger site said the price was around $125. Ebay is def. the place to go.
I have yet to use it (i've only disassembled and reassembled it...and yes, it is as easy as they say) but i've heard great things about the brush. I can't wait to get painting on my Academy 1/32 Hornet.
Posted by MikeV on Thursday, January 1, 2004 5:08 PM
That is a good price for a new one. They sell for $66 with free shipping from Dixie Art. Good deal my friend. Thumbs Up [tup]
What is rare, to impossible to get on Ebay though is a good deal on an Iwata.
They always sell for top-dollar.
Posted by Anonymous on Thursday, January 1, 2004 11:28 PM
ok. i'm an amateur on air brushes. i am thinking of buying a testors aztek a470 airbrush kit (tesa4709) $120.00 and a aztek air compressor ac300 (tes8883) $120.00. should i do it? i'm open to any suggestions from you more experienced guys. thanks.
Posted by MikeV on Thursday, January 1, 2004 11:46 PM
To be honest there is no way I would pay that kind of money for an Aztek airbrush. You can get a good Omni for about half that price that blows the Aztek off the planet. You could buy an Omni 4000 for $69.95 and a Silentaire Scorpion 1 compressor for another $139. That's $30 less than that Aztek setup and much higher quality and reliability. For another $20 more than you were going to spend you could upgrade and get the Omni 4000 with the Silentaire Scorpion II compressor. That would be a great modelling setup that would last you a long time.
Posted by Anonymous on Saturday, January 3, 2004 7:39 PM
simple. iwata revolution cr: $69.
paasche D500: $140
total: 209 + tax, same as omni 4000 and silentaire scorpion II.
Posted by MikeV on Saturday, January 3, 2004 8:35 PM
paasche D500: $140
You are joking right?
The Paasche D500 is junk compared to the Scorpion II.
The D500 is a diaphragm compressor that pulsates the airflow and overheats from it's simple design with no shutoff switch. The Scorpion II on the other hand is a dual-piston compressor that does not pulsate the airflow and does not overheat as it only comes on when you press the airbrush trigger.
There is no comparison whatsoever. Wink [;)]
Posted by Anonymous on Saturday, January 3, 2004 9:11 PM
Hate to tell you this Mike while Im sure the Silentaire is the better compressor over the Paasche D500...Mine doesn't pulsate like I was told it would....has yet to get warm either of cours Im not sitting there airbrushing for 2 hrs solid....I dont know any modeler who does....Only person I know who does that is Ben the local airbrush expert, but he has a business which does Auto work as well as other things.....
Of course I bought my D500 about 4 times below normal costs...If I had to do it all over again and had to pay full price for everything I would go with the Option MikeV posted. Never steered me wrong as of yet.
Maybe my D500 is just blessed LOL since it doesnt pulsate, though I have heard it is a common problem
