Question about hoses/adapters
Posted by Anonymous on Friday, December 26, 2003 3:53 PM
Well I finally gave in and got a Paasche VL airbrush for X-mas.... but the question I have is, I have a Sparmax mini compressor.... I bought a 10fft braided hose for my Paadche airbrush, but it doesn't fit on the compressor. Can you guys offer advice/help? Is there and adapter I can get?
Any help would be greatly appreciated. ^_^
Thank you
Posted by MikeV on Friday, December 26, 2003 4:36 PM
Go to a hardware store and find an adaptor.
The fitting on the compressor is most likely a standard 1/8" or 1/4" NPT pipe fitting and the fitting on the end of the airbrush hose is a 1/4" NPT fitting. Can you remove the fitting on the compressor and take it with you to the hardware store?
Posted by Anonymous on Friday, December 26, 2003 4:37 PM
Just go to your local hardware store that sells compressors and buy an adapter. If this compressor is small, (as it sounds Smile [:)] ) then take it with you and show the people there. They will get you the right fitting.
doh! Same info less text! :D (and pictures!)
Posted by Anonymous on Friday, December 26, 2003 8:54 PM
Hi there thank you for your response. The fitting on the compressor is 1/8" while the fitting on the hose is 1/4" Do you happen to have a picture of what adapter I would need to get or even the brand?? that would help greatly. ^_^
Thank you again for your help
Posted by MikeV on Friday, December 26, 2003 9:20 PM
If the fitting on the compressor is a male fitting then you need a 1/4" male by 1/8" female gas fitting like this:
The brand does not matter.
Do you have a Lowe's or Home Depot near you?
They would have them.
Posted by Anonymous on Friday, December 26, 2003 9:38 PM
Yes, the fitting on the compressor is a male fitting and the hose is female. I have both a Lowes and a Home Depot by me. ^_^
Thank you again for your help.
Posted by MikeV on Friday, December 26, 2003 9:49 PM
Glad I could help.
Now go get that fitting and get to painting with that new toy. Wink [;)]
Posted by Anonymous on Monday, December 29, 2003 1:30 PM
What is the view on using quick release fittings? My work area is not exactly permanent, and having quick release valves would make break down much easier. I can't think of a reason whey they would cause a problem.
Posted by MikeV on Monday, December 29, 2003 2:44 PM
Quick release fittings are fine, although they do tend to leak after a while.
