try not to leave the paint inside an airbrush for a long time. or else, the paint will start to clogg up the needle. you can still add more thinner to "wake up" the paint, but still, it can still hold a strong grip on the needle.
i have used enamel paints and tamiya acrylic paints. but i mostly use lacquer thinners to clean the airbrush. and even if i use lacquer thinners, there are small little acrylic and enamel paints that are stuck to the needle everytime i use the airbrush.
i need to take out the needle and wipe it off with a little thinner as well.
i seriously don't know the proffessional way to clean an airbrush though. especially the front of the airbrush where the paint shoots out from. how do you go inside the inside of the airbrush? so i am not 100% sure if thinner is all i can use to clean the airbrush.
as for consistancy of the paint, i guess it all matters on how you want it to look. in order for the paint to come out smoothly, i find that putting more thinner than paint helps i come out more smooth. sort of makes the paint come out more wet though. which may take a longer dryin curing time, if you shoot too much paint.
if you're gonna do detail painting, like masking off alot of parts, i found out that it is better off to use up alot of time to make it as perfect as possible to your liking, rather than just leave a sloppy paint sittin as your model.
i like to think paint as somewhat like food coloring. you only need to put a small amount so the entire thinner is pretty much the color that u want. i just let the thinner do the rest. but this is what i like.
masking is a pain. if i try to mask over tamiya acrylics after like 5 minutes, it sometimes works. sometimes the paint just chips off. so be very careful as to how much paint and how fast you apply the paint.
Fast = High Psi and how strong you pull that trigger.
