Ok, up until last week I hadn't used an airbrush in almost 5 yrs.
Now I have 2 airbrushes and 2 compressors.
Airbrushes are Paasche VL and Badger Omni 4000G
Compressors are a sears tank style(4gal?) and a Paasche D500.
In the past before I left the hobby I would normally spray at one pressure setting for 99% of my painting. I didnt know how various air pressures would change things.
Since last week I have been playing with pressure settings on the Craftsman comp, with both the VL and the Omni. For the most part I cant see a difference when using the VL at various settings while using properly thinned MM enamels and Testors or PollyScale Acrylics.
Now when using the Omni since it is a one part(needle/tip)setup, I find that using a lower pressure setting allows me a very fine line, but thats about it.
So when do you find you need to play with pressure settings, what pressure do you normally spray at?
For me its really been between 18-21 psi....
