Paint order
Paint order
Posted by Anonymous on Wednesday, December 31, 2003 9:13 AM
Hi there, just wanna confirm the order that would be best for painting.
1) paint primer
2) paint top coat
3) add decals
4) add future
5) add weathering/panelling effects
6) add future
????? did i miss anything???? would you suggest that order?
Posted by Anonymous on Wednesday, December 31, 2003 9:48 AM
Are you doing a military model if so dont for get the flat clear coat.
Posted by Anonymous on Wednesday, December 31, 2003 9:49 AM
I'm doing a B17G 1:48. So no future coating is what you're saying.
Posted by Anonymous on Wednesday, December 31, 2003 9:57 AM
You can do one coat of future (step 4) then finish with flat.Big Smile [:D]
Goodl Luck
Posted by Anonymous on Wednesday, December 31, 2003 9:59 AM
Decals are the most trouble-free when they're applied to a smooth, glossy surface (switch #3&4). If you plan on using pastel chalks for weathering, apply them to a flat finish. Seal the pastels with a flat finish, to protect them. I would suggest :
Primer
Top coat
Future
Decals
Future
Panel "wash"
Flat coat
Pastel weathering
Flat coat
Put on shelf & admire.
Posted by Anonymous on Wednesday, December 31, 2003 10:09 AM
Thanks!!!!
Posted by Anonymous on Wednesday, December 31, 2003 10:12 AM
Pix why do you put two coats of future just a??
Posted by Anonymous on Wednesday, December 31, 2003 11:31 AM
modelkid - the Future over the decals protects them from the wash (to give you panel lines over decals), and the flatcoat (if using lacquer/enamel base).
