hi guys,
my oil is starting to get a little low in my as shown by the little window on the side and i want to fill it up....however, i lost the original bottle and can't remember what sort it was!!
to make matters worse, although i bought the compressor from hannants in the UK, the instructions (which are TOTALLY cr*p
) don't actually say what sort of oil to use (duh!), indeed they don't even have the manufacturer's name and the model on the front!![:0]
i think it is an italian make as that is the instructions' first language, and it just says "15 EXPORT C-30H SILENT COMPRESSOR" and "serial no. 000631547" on the front.
it has a water trap, is electrically powered and can go from 6-88psi ...that's about all i can tell you guys.
your help would be very much appreciated, as otherwise my kitty is going to be left without a camo scheme over in the panther group build!![:0]
kind regards,
nick
