MESSED UP!! (stripping..!!!)
    March 2010
Posted by eboggs on Thursday, March 4, 2010 2:13 PM
Ok so i forgot to prime my model.. i know i know..so i was almost done with it..taped it up to paint bottom...BAM paint gone...tape sure looks nice though...being tan and all....anyway. i started to soak my model in Mineral Spirits..started to disassemble and BAM! plastic ripped (some of bottom wing stayed with top wing)...dont think this stuff is all that good for plastic...im an idiot.
Im using MM Acryl...how the H*** do i strip this stuff!?
(im also finding it hard to get out of my airbrush...)
Ethan....please help me!
    May 2005
Posted by Bgrigg on Thursday, March 4, 2010 2:31 PM
Most acrylics can be stripped by using Windex with Ammonia. Windex is mostly isopropyl alcohol with a dash of ammonia to give it some 'teeth'.
Wet acrylics can usually be cleaned up with plain soap and water, but if you've let it dry in your airbrush (naughty boy!) then you'll have to resort to lacquer thinner to get it loosened up enough to remove. BE CAREFUL! As some airbrushes have parts that will be dissolved in lacquer thinner!
Let us know what make and model of airbrush, and a resident expert will chime in with more precise instructions.
So long folks!
    March 2010
Posted by eboggs on Thursday, March 4, 2010 2:53 PM
i know i know haha...Its a Paasche VL model Double Action....I waited too long last time.. Sad wont happen again! haha
Ethan
Posted by Anonymous on Thursday, March 4, 2010 3:09 PM
Soaking parts in pure mineral spirits probably weakened the glue joints---I'm sure it can't be good for the plastic either...
    November 2003
Posted by bobbaily on Thursday, March 4, 2010 3:41 PM
Castrol Super Clean (found in the automotive section) is very good at removing MM Acryl.  I've also had success using Simple Green.
Bob
    July 2014
Posted by batai37 on Thursday, March 4, 2010 3:47 PM
Super Clean or Easy-Off Oven Cleaner is what I've always used.
    January 2003
Posted by Triarius on Thursday, March 4, 2010 4:47 PM
Mineral spirits and acrylic paints are incompatible. Do not mix. Soaking an acrylic paint in mineral spirits often turns it into goo.
However, mineral spirits should not affect styrene unless you soak it forever. Nor should it affect a solvent joint. Are you using tube glue?Surprise
    March 2010
Posted by eboggs on Thursday, March 4, 2010 7:09 PM
yep, red tube glue..
thanks for all the help guys!
Ethan
    October 2008
Posted by padakr on Thursday, March 4, 2010 9:07 PM
Simple Green.  Wonderful stuff.  Doog suggested it when I was stripping and not liking what mineral spirits were doing (/forums/t/109054.aspx).
And I use mineral spirits all the time to undo a solvent glue joint.
    September 2005
Posted by TB6088 on Friday, March 5, 2010 11:11 AM
Ah, your story brings back memories.  When I wanted to strip the bad acrylic paint job from my Tiger I, I was advised to use brake fluid.  It worked great.  Took the paint off easily and didn't damage the plastic--- however, it also dissolved all my glue joints, so I had nicely stripped plastic parts which had to be almost completely reassembled.  Live and learn..................
Tom
    January 2003
Posted by Triarius on Friday, March 5, 2010 11:17 AM
padakr
A true solvent joint is welded—the plastic is partially dissolved, intermixed, and resolidifies. While such joints are generally weaker than the surrounding plastic, they should not be affected by a solvent, such as mineral spirits, which is not particularly aggressive to styrene. "Paint thinner" on the other hand, may contain solvents that will attack styrene. Regardless, if you are soaking a model in either for long enough for a welded joint to be affected, then the rest of the styrene has also been affected. While mineral spirits is not particularly aggressive to styrene, prolonged soaking will soften the plastic.
And Simple Green is the greatest thing since sliced polymers…
    October 2008
Posted by padakr on Friday, March 5, 2010 9:56 PM
Triarius
 padakr:
While I don't soak anything in mineral spirits any more, I have brushed mineral spirits on a joint and been able to separate the pieces. Usually it is in an "Uh Oh!" situation where I glued something wrong, so maybe all I'm doing is interfering with the joint setting up.  I think I need to experiment.
    December 2009
Posted by Tucohoward on Saturday, March 6, 2010 7:22 AM
I use MM Acryl and strip with Gunze Mr. Thinner on a Q-tip.This takes it off easily. I also use it to blow through the airbrush when done painting. I haven't had to disassemble an airbrush in years as this seems to keep them very clean.
The Mighty Mo says no.
    January 2003
Posted by Triarius on Saturday, March 6, 2010 8:36 AM
Mineral spirits will definitely interfere with the liquid welding process. Good tip!
