How to mount model for painting
Posted by Anonymous on Sunday, January 4, 2004 1:35 AM
Question [?]When painting car bodies I have found that using a bent metal coat hanger is an effective "mount." But with aircraft, when the paint goes all around the model, I can't visualize what to do. I could hold it in my hand (wearing a latex glove), but then what do I set it on when I'm done? I could paint the top one day and the bottom the next, but won't that leave a tell tale line? I could suspend the model from a small hook, but then I can't visualize how to stabilize it while applying the paint.
Is a puzzlement! Any suggestions?
    December 2003
Posted by thevinman on Sunday, January 4, 2004 1:52 AM
In the past, I've always made creative mounts/hangers. Frankly, it depends on the models design.
Most of the time, I end up doing something like this:
Some kits allow for convenient hanging points. With some thin wire I can usually find a loop or hole to string it up for hanging. In addition, I use a piece of sprue carefully shaved and lightly stuck into an empty landing gear hole or empty propeller hole for stabilization with the free hand.
White glue works to temporally hold mounting sticks in various holes of an un-finished model. A little water and the glue softens up and cleans up nice.
It's ugly, but it works, most of the time.
Any other ideas out there?
Posted by MikeV on Sunday, January 4, 2004 2:05 AM
For jets you can usually wrap some tape around a wooden dowel and insert it into the exhaust opening in the fuselage since the engine burner cans can go in last. If it is a sigle color you can paint it and then hold the dowel in a vice or something while it dries.
Posted by maddafinga on Sunday, January 4, 2004 12:09 PM
Since the bottom has been a different color than the top on every plane I've made (2) I've just painted one side and set it on the other to dry. As long as I paid special attention to the boundary, I've had no problems at all doing it that way.
Madda Trifles make perfection, but perfection is no trifle. -- Leonardo Da Vinci Tact is for those who lack the wit for sarcasm.--maddafinga
Posted by Anonymous on Sunday, January 4, 2004 7:15 PM
Thanks to all! Vinman and MikeV, those are good ideas and I can visualize how that would work. I have both prop jobs and jets, so I appreciate the multiple suggestions.
Maddafinga, most of my models are also "two-toned" because I specialize in tailhook aircraft, but I would like to prime them first (I've heard that's a good idea). with a single color.
    December 2003
Posted by thevinman on Monday, January 5, 2004 12:18 PM
Priming = Very Good Idea
I just recently screwed up a Future application and tried to wash it off. No primer and Tamiya acrylic base coat…there went my paint job, down the sink!
..almost done repainting. Live and learn.
