removing paint
removing paint
Posted by pingtang on Sunday, January 4, 2004 9:22 PM
Gidday
I was wondering if anyone had any tips for completely removing tamiya TS spray paints as well as decals. I've put on a base coat, decals and a clear coat but now need to remove them because the tamiya decals on another part got ruined when I sprayed a clear coat over them.
So I am getting different decals. Any help would be great.
Thanks
-Daniel
    January 2003
Posted by shermanfreak on Sunday, January 4, 2004 9:45 PM
Oven cleaner and an old tooth brush is probably as good a method as any. Spray the model with the cleaner, let it set for a while, and then scrub with the toothbrush. Repeat if necessary.
Posted by MikeV on Sunday, January 4, 2004 10:11 PM
Here is all the info you will need on what to use:
http://www.bonediggers.com/1-3/strip/strip.html
