lacquer thinners are probably the strongest out of all of them, so that's what i use after, i clean with alcohol.
but what i don't really understand is, "How do you Clean," the airbrush.
i used to just put alcohol right after i was done with the acrylics. and then just shoot that thing out to be cleaned. and i realized, that there are always small bits and grinds either stuck to the needle, or inside the airbrush where it holds the needle.
so i decided to use lacquer thinner right after it. but still i found small bits of black paint still stuck inside the airbrush that i couldn't reach with just liquid.
how do i clean out the "Entire" airbrush? i mean, a fully clean airbrush as if i'm using a brand new one?
do i leave the entire airbrush inside some liquid container? i heard about people just soaking the airbrush in overnight, but i also hear that this will destroy a few parts. but i'm not sure.
