I posted this on another forum and thought it may be helpful here also.
I have of course updated my post from the other one and changed a few things that I thought were necessary.
I thought this might be helpful to those who ask this question so often.
The size of the airbrush needle and tip are dependent on the medium that is being sprayed. You cannot take an airbrush such as the Iwata Custom Micron and spray Model Master enamels through it and expect it to perform the way you want as the nozzle is too fine for enamels with such big pigments relative to the nozzle size.
Airbrushes such as the above mentioned Micron, as well as the Paasche AB Turbo, and the Badger Sotar were designed to handle very fine pigment mediums such as inks, watercolors, automotive urethanes, and fine pigmented acrylics. These were designed for the finest lines possible, but only with the mediums they were designed for.
Will they work with modeling paints? Yes, but not reliably and not without a lot of problems.
If you want an airbrush that will spray the finest lines possible with paints such as Model Master enamels, and others of similar pigment size then an airbrush like the T&C (Badger)Omni , Vega, Anthem, and 360, along with the Iwata Eclipse, Revolution and others like the Paasche VL are all good choices.
Just because an airbrush has a smaller tip and needle than another model does NOT mean it will spray a finer line, that is a misconception that people have. The finer tip and needle only means that it will spray a finer line with the medium it was designed for. That is why the Sotar with fine pigment acrylics will spray a finer line than my Omni 4000 in capable hands, but if you put Model Master enamels in the airbrush then the Omni will spray better than the Sotar for the most part. So just remember that the finer tip illustrator airbrushes are not necessarily the best choice when it comes to fine lines, it all depends on the medium being sprayed.
The most important factor as always is the skill of the user.
I could give a beginner an Iwata Micron CM and I could use a Paasche VL with a #1 or #3 tip and I bet I could get a much finer line as could many of you.
I think my buddy Scooter who has been in the airbrushing business for close to 30 years summed it up best when he told me recently:
"I can get just as fine a line out of a $10 Ebay sold Taiwanese knockoff as I can with a Sotar or Micron using the same paints. It isn't the tool so much as it is the developed skill. A Ferrari can be more fun to drive, but a Toyota will get you there just as well."
Those are words of wisdom.
