keilau:
This Paasche H was the first airbrush that I acquired in the mid 1980's and my only one for the next 20 years. It does the job of airbrushing models, but I never could have figured out a good way of cleaning it. I took it all apart and soak it in thinner in-between colors. Well, not surprisingly, it did not get used a lot. I no longer use it. The Badger Patriot works equally well for larger areas and is easier to clean. For general airbrushing, I go back to the Iwata Eclipse.
I have to agree that the Patriot is a nicer airbrush. But, it sells for $72.95 at Coast Airbrush vs. $30 for the H. And I feel the Paasche H is still a good airbrush that can meet most modeler's needs.
I am curious about your problem cleaning the Paasche. I actually timed myself, and I can remove the tip and needle in less than 30 seconds. And I can put them back in another 30 seconds. The tip can be cleaned out with a twisted piece of paper towel and some thinner, and the hollow needle with a pipe cleaner and a toothpick and some thinner. The head can be cleaned with a small paint brush. I think the whole operation takes less than 5 minutes. Were you tearing it down more than that? Did you find that just purging with thinner was not good enough when doing a color change? Did you see color mixing? The cup takes a little extra work, but that's true for any siphon brush.
Don
