Paints
Paints
Posted by Anonymous on Thursday, January 8, 2004 3:10 AM
I have just purchased my first Tamiya kit and I only have Humbrol paints, I was wondering if It would be better to buy the paints required in the Humbrol conversion since I already have a few of the paints needed or If I should just buy the whole lot in Tamiya paints. I have never sprayed acyrilcs and dont know how well they perform any feedback would be much appreciated. Thanks.
    August 2003
Posted by South Aussie on Thursday, January 8, 2004 4:37 AM
I have used both the Humbrol and Tamyia paints and am quite happy with the results from both. I find the Tamyia paints are good for airbrushing but it does take time to be able to acheive a good result when hand brushing.
If you are set up at this time to use Humbrol and are happy with them I would keep using them and maybee experiment with the Tamyia Acyrilcs till you gain experience with them.
Wayne I enjoy getting older, especially when I consider the alternative.
    July 2003
Posted by saltydog on Friday, January 9, 2004 12:04 AM
i use tamiya acrylic exclusively and thier brand of thinner and have never had the first minutes trouble with them. they smell very sweet too, almost drinkable. i never get high from the fumes. youll love them if you make the switch my friend.
Chris The Origins of Murphy's Law: "In the begginning there was nothing, and it exploded."!!! _________ chris
Posted by Anonymous on Friday, January 9, 2004 3:15 AM
Couple of minus with the Tamiya acrylics:
1 They take some skill to brush paint on larger areas.
2 They have a limited color range.
They are great for spraying for sure. You can also use your Humbrols together with the Tamiya. Just don't mix them together. Make sure one is cured before covering with the other one.
