I don't like the way I painted the white lettering on the tires. I would like to remove ALL the paint from the tires and start anew. What can I use to safely remove all the paint on the tires?
Best way to paint the raised GOODYEAR lettering?
If you used acrylics, soak in ammonia or windex. If enamel base (freshly painted) try brushing some paint thinner to remove the paint. Only way I know to paint the lettering is with a very fine brush and a steady hand.
Thanks for the reply Plastic! Unfortunately, being a perfectionist led me to asking this question before I started work. I did eventually use Tamiya Acrylic Thinner on the tire and removed all paint. I then bought a 5/0 brush and used the 3x magnifier on my task lamp and forged ahead. I was surprised at how steady my hand was. Now the challenge is the smaller lettering opposite the GOODYEAR. Thanks again!
Your welcome. I use an optivisor for just about any small detailing.
If the letters are raised a fair bit try dry brushing the white.
I never to rarely use magnification as it reduces depth perception in my experiences.
SuppressionFire I never to rarely use magnification as it reduces depth perception in my experiences.
That's probably because you don't wear tri-focals God bless your eyesight.
A couple of times I have made a stamping tool. Cut a piece of about 3/16 square balsa about one inch long. Make sure one cut is very square and flat. Then, I shake the paint (enamel in my case) and remove the cap, putting it down upside down on bench. I dip the end of the stamp in cap, the residual amount is typically about the right depth. Then I stamp onto raised lettering (this only works with the raised stuff, of course). I don't really know if this is that much better than just painting it- seems so to me but you still need to touch up with fine brush or toothpick.
