Representing Burnt metal other than MM Metalizers
Posted by wjbwjb29 on Friday, August 13, 2010 6:52 PM
Hello;
Does anyone know of a way to show the burnt metal effect on exhaust other than the MM Metalizer paints. I am building the AM F3F-1 and I need a little burnt metal color on the Exhaust ports.
Bill
On the Bench:   Trumperter Tsesarevich on deck Glencoe USS Oregon
    July 2004
Posted by mucker on Friday, August 13, 2010 7:17 PM
Gunze makes a Mr. Metal Burnt Iron which is fairly convincing.
    August 2005
Posted by Phil_H on Friday, August 13, 2010 7:31 PM
Tamiya have a "burnt blue" and "burnt red" in their "Weathering Master" set D. The weathering master sets are similar to pastels and are applied in a similar way. Paint the item a dark (metallic) grey and apply lightly with the supplied makeup applicator.
    June 2010
Posted by DoogsATX on Friday, August 13, 2010 8:32 PM
Alclad II Exhaust Manifold. Used it on some Ultracast manifolds recently and loved it.
On the Bench: 1/32 Trumpeter P-47 | 1/32 Hasegawa Bf 109G | 1/144 Eduard MiG-21MF x2
On Deck:  1/350 HMS Dreadnought
Posted by Wingman_kz on Saturday, August 14, 2010 12:25 AM
That's exactly the color I need. Thanks for posting that.
Tony
Posted by Don Stauffer on Saturday, August 14, 2010 9:22 AM
I just use  regular colors. On chrome stacks and pipes I use blue and red- very, very light airbrushed coatings. On weathered steel and darker metal stacks, a rust color and a little blue works well.  There are lots of "rust" colors in various brands.
It helps to use a DA brush, but I have adjusted my SA Badger down to low enough flow to do a decent job a couple of times.
Posted by wjbwjb29 on Saturday, August 14, 2010 11:52 AM
Hello;
I might try adding a little rust color to a steel color and see what thats like.
Bill
Posted by Don Stauffer on Sunday, August 15, 2010 11:01 AM
wjbwjb29
Hello;
Bill
If you mix the colors before applying, you will get a reddish silver.  I recommend drybrushing the rust, because typically on exhausts the rust patina is not uniform.  So you either need to airbrush the rust with a very fine light coat, or drybrush it.
Posted by wjbwjb29 on Sunday, August 15, 2010 11:20 AM
OK thanks that sounds better than mixing the paint before hand.
Bill
