Iwata and Paasche-same hose?
    December 2009
Posted by docbailey on Saturday, August 28, 2010 5:36 PM
Hi All, i just ordered a Iwata double action Revolution air brush.. Currently, i have a Paasche VL. Can you use the Paasche air hose with the Iwata, or do i need to order a new one.and if i need a new one could someone please tell me what to order.  Any help ASAP will be greatly appreciated. thanks Doc Bailey
    May 2005
Posted by Bgrigg on Saturday, August 28, 2010 6:41 PM
The hose will work fine. The hose FITTINGS will not. However, you can buy a Paasche to Iwata adapter. Or better yet, you can buy a set of quick connects and be able to swap the VL for the Iwata quickly.
So long folks!
    April 2004
Posted by keilau on Sunday, August 29, 2010 10:09 PM
docbailey
The Iwata airhose is almost like an industrial standard that can be used with almost any airbrushes except the Badger and Passche. A generic one is about $6-7 from places such as Habor Freight. The Iwata airhose is $12 at Hobby Lobby using the 40% coupon.
For the long run, an Iwata hose is probably a better investment than an adaptor to use with a Passche hose. The adaptor is cheap ($2-3), but shipping usually is not ($6-10).
