Using Tamiya Surface Primer for Plastic & Metal(gray)
    November 2008
Posted by Arespontus on Monday, September 20, 2010 1:31 PM
Hello everyone
I was wondering. I have been using Surface Primer for Plastic and metal on my models before I paint them with my Tamiya waterbased paints.
My question is, is this necessary? Is it better to use a primer before you paint?
One of the projects I'm working on is a B-17 Flying Fortress and I tried painting the interior of the bomber with silver. I did not use any surface primer and I could not tell the difference between using the primer and not.
This would save me a little bit of money not having to paint with the Tamiya Surface Primer. However I want to make the best possible model and if using primer is better then this is what I want to use.
One thing I noticed about using the primer is. If you make a mistake and you try dipping the part in Windex the primer will not come off but waterbased tamiya paints will come off. I figured this out on a model of a AH-64D.
Thank you,
Scott
    June 2010
Posted by DoogsATX on Monday, September 20, 2010 1:40 PM
Personally, I always use primer. I've found it provides a "grippier" surface for the paint and tends to prevent paint lift-off when masking and such.
For interior parts and minor bits (tires, etc) I typically use Tamiya primer. For the outside surface, I've fallen in love with Mr. Surfacer 1200.
That said...I just threw my can of Tamiya white primer in the trash a few days ago. I've been trying to use it to lay down a white undercoat for my yellow wing Wildcats, and from the can it was just ridiculously runny. Decanted and sprayed through the airbrush, it went all congealed and resulted in a night spent sanding both planes smooth again (and now I have to overspray white again to provide a base for the yellow...sigh).
On the Bench: 1/32 Trumpeter P-47 | 1/32 Hasegawa Bf 109G | 1/144 Eduard MiG-21MF x2
On Deck:  1/350 HMS Dreadnought
    July 2010
Posted by robtmelvin on Monday, September 20, 2010 3:04 PM
Scott,
I'm a long way from a highly experienced modeler, but I do always prime.  To me it provides a better base surface for the finish coats than just bare plastic.
I have had very good luck using Kryon Fusion rattle cans, in either white or grey, for a primer.  It is cheaper than say, Tamiya primer, and so far I have no complaints.  Drys very quickly to.  IMHO.
Bob
Just launched:  Revell 1/249 U.S.S. Buckley w/ after market PE and guns.
Building: Italieri 1/35 P.T. 596 w/ Lion Roar PE.
    August 2005
Posted by Phil_H on Monday, September 20, 2010 6:22 PM
Arespontus
Scott,
Are you referring to the  spray primer or the 40ml bottled Liquid Surface Primer?
The bottled primer is nominally a lacquer based product which will be unaffected by Windex, but it can be removed using denatured alcohol (but not Isopropyl). Note that Denatured alcohol will rip Tamiya acrylics off faster than Windex.
    April 2009
Posted by deafpanzer on Tuesday, September 21, 2010 7:50 PM
I have been using this primer from Walmart (store branded)... it has been working great for me.  Best part it is very cheap as you can buy it for only $1.15 and it lasts for a long time unlike those Tamiya primers.  Maybe this helps if money has been an issue.
But I recently bought Mr Surfacer 1200 and I can't wait to use it on my figures soon.
Andy
    October 2005
Posted by usmc1371 on Saturday, September 25, 2010 8:15 AM
I used to use Tamiya's Primer before painting with Tamiya acrylics.  I read in one of Steve Zaloga's books the he doesn't.  I gave it a try not using primer and I saw no difference.  The only trick is to have a really clean surface before painting.  I even painted over photoetch without priming using Tamiya acrylics.  Once again, the paint adhered just fine.
-Jesse
