Two materials come to mind - for either I would copy said page of instructions to work from, just in the event you have any little accidents while cutting;
Lay down some overlapping masking tape, or some Frisket Film (masking film) on a hard, flat surface (glass sheet, large plate....).
Put your copied instruction sheet over the masking material (you may want to tape it down to prevent any unwanted movement) & cut the mask with a fresh blade - voilà.
Masking tape you will most likely have, Frisket film can be found online easily - usually in artist supplies shops or airbrushing shops.
I assume you are in the US?
