Which paint thinner?
    November 2010
Posted by Dan the Man on Friday, November 19, 2010 11:26 AM
Is it ok to use your regular hardware store paint thinner when trying to thin enamel paints for use in the airbrush an/ or make washes for weathering?  Must one spend the same amount of money on 150 milliliters that you do on 1000 ML from the paint department?
Completed: Confederate Squadron F6F Hellcat
On the Bench: Monogram TBD Devastator
On Deck: Likely a piece of German Armor.
    June 2010
Posted by DoogsATX on Friday, November 19, 2010 11:34 AM
You most certainly can. That or mineral spirits, with enamels.
Personally, I've found I get better consistency (and less odor) out of the modelling thinners. I use the good stuff to thin and the harsh stuff to clean up with.
On the Bench: 1/32 Trumpeter P-47 | 1/32 Hasegawa Bf 109G | 1/144 Eduard MiG-21MF x2
On Deck:  1/350 HMS Dreadnought
    November 2010
Posted by Dan the Man on Friday, November 19, 2010 11:44 AM
So I understand you to say that it is ok to to use the hardware store stuff to thin enamels with, but you get better results from the model paint thinner. I've tried mineral spirits (the one in the white plastic jug with a green label), but find the milky  color of the mineral spirits reduces the color intensity too much.  Is there a clear mineral spirits?    What about Turpenoid from the artist's section at the hobby shop?
    June 2010
Posted by DoogsATX on Friday, November 19, 2010 11:57 AM
Dan the Man
Where are you buying? I know what goes for mineral spirits here in the US is often called white spirit elsewhere.
The mineral spirits I buy are Crown Low Odor Mineral Spirits from Lowe's. Comes in a blue metal tin. It's absolutely clear.
I haven't used Turpenoid...I know it's recommended for pin washes because it does the capillary thing so well, but it evaporates extremely quickly so it may not be best of the airbrush. Personally I use oils and Mona Lisa Odorless Thinner for washes. Stuff's very mild. It thins the oil paint but doesn't mess with cured enamels (though I'd recommend a clear coat anyway, just in case!).
    August 2006
Posted by HawkeyeHobbies on Friday, November 19, 2010 1:17 PM
You can use lacquer thinner as well, it dries much faster, just don't pour any unused thinned paint back into the bottle...you'll kill the paint in the jar prematurely.
Gerald "Hawkeye" Voigt
