airbrush backflow problem?
    July 2004
Posted by stikpusher on Friday, December 3, 2010 6:18 PM
I have having a problem with my airbrush the past few times I have used it. Unless I have it nearly "wide open" for paint flow, it is instead back flowing and blowing air down into the paint jar. My airbrush is a bottom feed internal mix single action made by Thayer& Chandler for Promodeler. It most closely resembles the T&C Vega model 600(essentially identical). Until recently I never had this problem. On close examination, the needle tip is slightly bent and the nozzle slightly split at the tip. Is this the most likely source of the problem I am having? I have ordered replacement parts so replacement is not an obstacle.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    August 2005
Posted by Phil_H on Friday, December 3, 2010 6:29 PM
Hey Carlos,
Yep, a split/cracked nozzle is your most likely suspect. Blowback may also occur if the nozzle and/or air cap isn't fully seated.
    July 2004
Posted by stikpusher on Friday, December 3, 2010 6:34 PM
Thanks for that info Phil. I noticed that the problem was reduced a bit when I tightened up the nozzle and air cap, but not eliminated.
       - Plankton
LSM
    March 2010
Posted by ACESES5 on Sunday, December 5, 2010 3:22 PM
Make sure the vent hole in paint bottle cap is not pluged up .  ACESES5            ON BENCH FUJIMA 1/48 BF110C/D
