Which Type of Acrylic Paint is best for airbrushes?
Posted by Anonymous on Friday, January 16, 2004 8:07 AM
Please give your views on which type of Acrylic paint is best. Most of the time I use Tamiya Acrylic Paints. Sad [:(]Sad [:(]
Posted by Anonymous on Friday, January 16, 2004 3:50 PM
Carnage, Tamiya acrylic paints in my experience are one of the best for spraying. What problems are you having? Try thinning with Tamiya thinner at about 50/50, set your air pressure at about 15 - 20 PSI, and go from there. Or do you already do this? Sorry I can't be more of more help, not enough info.
Cheers...Snowy.
    December 2003
Posted by thevinman on Friday, January 16, 2004 5:39 PM
Sign - Ditto [#ditto]
Tamiya Acrylics are pretty good. Are you using Tamiya Thinner? That's the key to the smooth spraying of Tamiya Acryls.
Posted by MikeV on Friday, January 16, 2004 7:17 PM
The best is what works for you. Wink [;)]
Many swear by Tamiya and Gunze, and many swear by and at MM acrylics. Laugh [(-D]
Posted by tigerman on Friday, January 16, 2004 7:32 PM
I usw Model Master Acryl's and they work well. I don't dilute them as much as recommended say 50/50. I'm more 70/30 or 80/20. They flow pretty well.
I do shoot Tamiya and I have heard and tried mixing Tamiya and alcohol (which most people say is the tamiya thinner anyway) together and am happy with the results. Good luck.
 Eric
    July 2003
Posted by saltydog on Sunday, January 18, 2004 8:58 PM
its been my experience that tamiya acrylics perform better than polyscale or mm acryl. thats just my view though. tamiya goes through my omni 5000 with little if no hassle. keep experimenting and youll find that sweet spot. later.
Chris The Origins of Murphy's Law: "In the begginning there was nothing, and it exploded."!!! _________ chris
Posted by Anonymous on Sunday, January 18, 2004 9:09 PM
Have to agree with saltydog.
Keep experimenting till you find the mix/setup that suits you and your needs.
Even if people share the same equipment/local conditions, etc you will find that their mixes are different.
Nothing like good or bad paint/airbrushes/compressors(for the most part).
One of my friends used to solely use golden paints in his airbrush, till he switched over to Gunze because he couldn't get hold of Golden anymore. Didn't affect the finish/outcome in any way that I can see.
Posted by Buddho on Sunday, January 18, 2004 9:23 PM
I like Tamiya paints too....as long as Tamiya thinner is used with it!
Regards, Dan
Posted by MikeV on Sunday, January 18, 2004 9:45 PM
Your friend knows good paints when he sees them. Wink [;)]
Golden's acrylics are the best acrylics produced period!
I don't know how well they work on plastic models but for hard surfaces like metal they are the best out of the acrylics.
Posted by Anonymous on Sunday, January 18, 2004 11:32 PM
Geesh no mention of Vallejo, guess not everyone can get it yet.....
Vallejo is an awesome acrylic that airbrushes just as well as it brush paints(BTW for brush painting dont want brush strokes, dont want to have a magic thinning ratio to reduce brush strokes, go with Vallejo right out of the bottle! I have yet to experience ONE SINGLE brush stroke!)..........
I also use Tamiya acrylics, I swear at MM Acryl more than I use them, though I am still "experimenting" with the few colors I have left.
I've seen others use Poly Scale and get flawless results.....Much to my frustration I just cant use this crap......Might just be me but I doubt it.
Posted by Anonymous on Sunday, January 18, 2004 11:34 PM
He does mostly Model Planes and Anime Resin Kits, won a few prices too.
Posted by MikeV on Sunday, January 18, 2004 11:50 PM
The Golden Artist Colors were all that this lady named Gina G used to use on her artwork and it looked awesome. http://www.ginag.com/
Check out her Motorcycle and Automotive links when you are there. [:0]
I used to talk to her in emails once in a while and she liked my airbrushed work so much that she offered me a lesson at half off if I ever made it out to Port St. Lucie, FL anytime. She passed away from cancer a few months back unfortunately. She was one of the best airbrush artists I have ever seen and I sure miss her. Sad [:(]
Posted by Anonymous on Sunday, January 18, 2004 11:55 PM
Thanks, for the link very inspiring.
