Progressing on my first serious plastic model to 1:72 scale.
Come across a problem with one of the colours a Humbrol 106 enamel.
Using a Harder & Steinbeck Evolution air brush which after lots of
practice I am able to use in a rudimentary fashion getting reasonable results.
Two other colours I have airbrushed the wings fuselage with have, this being my
first, have turned out OK. But the third as mentioned above has not.
The coats have turned out streaky & patchy. Sure this is not air brush
problems as those colours I have applied successfully were applied before &
after the problem one.
I have wet & dried & reapplied coats but no improvement. Used 2/1
& 1/1 mixes. Also used a brush in frustration but with the same results.
Just to confirm that I have meticulously stirred the paint & finally before
use mixed with a mechanical stirrer.
Thought did pass by as to if the paint was faulty. I have emailed Humbrol
with the above to see what they have to say.
Very sad as I have taken a lot of trouble & patience (for me) over this
small model to set down my techniques of construction. Can any body please help?
Matter of interest which enamel do you recommend. Are there those better
than others or is it just finding one that suits your own technique.
Thanks in advance.
Laurie
