Will enamels eat lacquer?
cml
    March 2007
Posted by cml on Monday, December 13, 2010 6:53 AM
Hi all,
I'm sure this has been asked and answered so many tiems before...but here goes again.
I've just overcoated my recent project with Testors Clear Lacquer (i might add, i painted with Gunze, then did an overcoat - which ended up eating into the Gunze and required re-painting, then i did overcoats of acrylic clear before the Testors Clear Lacquer).
Anyhow, i now have a nice glossy surface to do panelwashes.  I normally use enamels for panel washes, however, will the enamel thinner eat into the clear lacquer?  Should i use acrylics for the washes instead?
Thanks in advance.
cml
Chris
Posted by Don Stauffer on Monday, December 13, 2010 9:58 AM
Usually enamel can go over lacquer but not vis versa.  However, not all lacquers are equal these days, nor are all enamels the same.  So there may be general rules but they are not perfect.  Best to experiment with scrap for specific paints.
However, I have specifically used Testors enamels for washes over both Dullcoat and Glosscoat without a problem.
Posted by rjkplasticmod on Monday, December 13, 2010 10:23 AM
As a Rule-Of-Thumb it's best to use acrylic washes over enamels & lacquers & enamel washes over Acrylics.  For a wash, never use laquer thinner to thin enamels or oils.  I use Mineral Spirits or Turpenoid.
Regards,  Rick
    June 2010
Posted by DoogsATX on Monday, December 13, 2010 11:00 AM
You might want to try picking up some Mona Lisa Odorless Thinner from Hobby Lobby. I've used it for artist oil washes over Future, clear lacquer and cured enamel with absolutely no problems (though I probably wouldn't recommend making a habit of the last). It's a very gentle thinner that, in my experience, thinned the oil paint and didn't do squat with anything beneath it. I'd guess it can probably thin enamels for wash purposes but I haven't tried that yet.
On the Bench: 1/32 Trumpeter P-47 | 1/32 Hasegawa Bf 109G | 1/144 Eduard MiG-21MF x2
On Deck:  1/350 HMS Dreadnought
cml
    March 2007
Posted by cml on Tuesday, December 14, 2010 7:17 AM
Thanks for responses.
Given i have a huge array of acrylics (as these are my normal paints i airbrush with) i think i'll have a go at doing a wash using them, rather than enamels.
I've never tried acrylics before for this - so hopefully they'll perform the same as enamels.  If that fails though, i'll have to do some experimentation and use enamels over the lacquer.
Thanks for the tips and suggestions on the types of thinners too.
Chris.
Chris
