Alternative to base/primer for Alclad II
    April 2010
Posted by El Taino on Tuesday, January 11, 2011 10:47 AM
Hello guys and gals, here again with another question. I have used Alclad II for small parts and areas with no problems at all. But I'm currently working on a F100 Super Sabre (Monogram) and I have never painted with Alclad a complete model. My local dealer has everything but their native primer. Any other alternative? I know Alclad suggest a gloss base color. Will Acryl or Tamiya gloss work?
Thanks in advance for your usual help.
    June 2010
Posted by DoogsATX on Tuesday, January 11, 2011 10:55 AM
You only need gloss black if you're using the "high-shine" Alclads - so Chrome, Polished Aluminum, Airframe Aluminum, and Stainless Steel I think.
And yes, Tamiya X-1 works very well. When I was Alclading a wing recently, I used Tamiya X-1 + Tamiya Clear cut with Gunze Mr. Leveling Thinner as the base and it worked out very well:
If you're going with Duraluminum or something, you just need a smooth surface, but not gloss black necessarily. I've read of people having great results using Tamiya AS-12 as a base and think I'll try it on my next go-round.
On the Bench: 1/32 Trumpeter P-47 | 1/32 Hasegawa Bf 109G | 1/144 Eduard MiG-21MF x2
On Deck:  1/350 HMS Dreadnought
    April 2010
Posted by El Taino on Tuesday, January 11, 2011 11:22 AM
Thank you so much Doogs, that's some helpful info. I visited you Blog and saw the rest of the pictures and work in progress.
Cheers!
    November 2008
Posted by plasticjunkie on Tuesday, January 11, 2011 2:46 PM
Taino
If you just want to buy one bottle of Alclad and get different subtle shades, try this:
Use different shades of gray and black and even white in selected panels and let dry. The glossy paints will give a smoother finish, flat ones will give a weathered look. Then spray the Alclad on lightly misting as you go. The different basecoat shades will alter the Alclad topcoat and give different subtle panel tones. Way cheaper than buying several Alclad shades.
 GIFMaker.org_jy_Ayj_O
    April 2010
Posted by El Taino on Tuesday, January 11, 2011 3:23 PM
Thanks so much for the tip Junkie, I will give it a try for sure.
Cheers!
