I'm not an aircraft builder but I do have a Paasche H that I use. It depends on whether or not you are painting a camo pattern. If so, use the #1, for just your base coats the #3 should be fine.
For pressure, between 15 & 20 PSI for base coating and a little lower for fine work.
Happy Modelling and God Bless
Robert
