Am I doing this right? When I use my airbrush the cleaning takes more time than the painting. I use a Badger 200 NH single action internal mix brush. I get good results with it but I'm wondering if I am over cleaning. Heres the procedure.
- Detach the paint jar and spray air until no paint is coming out of the brush.
- Spray enamel thinner through the brush until that is clear.
- dissamble the brush ie. remove the needle, nozzel, and tip.
- Soak them in solvent while cleaning the body of the brush.
- Clean the needle, nozzel and tip.
- Reassemble the brush.
- Spray solvent (about 1/4 oz.)
I do this even for color changes. Am I over cleaning??? Would I be better off with a gravity fed brush?
Thanks
