Practicing freehanding airbrushed camo
    December 2006
Posted by sarge on Saturday, March 19, 2011 7:35 PM
One of these days I am going to try freehanding camo onto an actual model.  I have a sheet of styrene to practice on, but rather than burn through my little $2.50 bottles of Tamiya acrylics practicing, does anyone know of a suitable medium with which to practice?  The manual that came with a Paasche VL I have suggested India Ink.  The guys I spoke to at an art store seemed to not think that was a good idea.  So, any suggestions based on experience?
p.s.  is cleaning up after airbrushing acrylics as easy as it seems or am I dreaming?
    August 2005
Posted by Phil_H on Saturday, March 19, 2011 8:11 PM
Just my opinion, but they guys at the store are right - don't use Indian ink
Always practice with what you're going to use. Big Smile
    May 2003
Posted by kirk4010 on Saturday, March 19, 2011 8:14 PM
You need to practice with the actual paint your are going to use.   A big part of air brushing is the correct thinning of the paint and compressor setting.   All these variables will change depending on the paint.
The cleanup was one of the reasons I went with acrylics over Enamels.   Keep your Windex handy.
The art of war is simple enough. Find out where your enemy is. Get at him as soon as you can. Strike him as hard as you can, and keep moving.-Ulysses S. Grant
    October 2008
Posted by Don Wheeler on Saturday, March 19, 2011 8:33 PM
If you just want to practice brush handling and trigger control, ink or food colors work well on paper or paper towels.  I've found that coloring in comic strips with food colors is a good exercise, and it's super cheap and easy to clean up.  But, it's not the same as painting on plastic.  Decanted spray paint is cheap, but you have to deal with the fumes.  I've heard of people spraying craft acrylics, but I've never tried it myself.
Don
https://sites.google.com/site/donsairbrushtips/home
A collection of airbrush tips and reviews
Also an Amazon E-book and paperback of tips.
    February 2011
Posted by MAJ Mike on Saturday, March 19, 2011 9:40 PM
I'm still in my earliest stages of using an air brush, too.  The best advice I've seen is to pratice with what you'll use.  You don't prep for a pistol competition by using a water gun.  You shoot your competition piece at the distances used in the match using match loads.
Check out Fine Scale Modeling's special issues on air brush painting.  There's a ;ot of tips there regarding compressor settings and paint mix ratios.  Probably a good idea to keep notes on settings and mix ratios everytime you paint.  That way you won't make the same mistakes over and over again.  With my 4th air brush effort, things are looking better.
 "I'd "I'd rather be historically accurate than politically correct."
"Sic gorgiamus allos subjectatos nunc!"
    July 2009
Posted by AlterEcho on Saturday, March 19, 2011 10:04 PM
I am currently working on my second model. My first model, that I built and painted, was a hasegawa 109. To prepare for painting I bought parts of models and partial kits at yard sales. Then I bought a few bottles of Tamiya paint and Tamiya lacquer. The lacquer allowed me to thin the paint and also make it last longer. Then I practiced painting and cleaning my airbrush. I did this for a couple of weeks, until I felt very confident in using the brush. Now I am pretty good at free hand and mottling. It is like the guys here are saying, pratice until you are confident and at home cleaning and using your brush. At that point the paint you used for practice will pay off by allowing you not to make very many mistakes. Here is my '109... all free hand.
  BTW...I did not free hand the white stripes or propeller  Wink
    October 2008
Posted by Don Wheeler on Saturday, March 19, 2011 10:44 PM
MAJ Mike
Maybe not a water gun, but I bet you spent a lot of time with other firearms learning the basics before you touched that competition piece or those expensive match loads.  Smile
There are stages in any learning process.  Trying to jump too far ahead can cause major frustration.  Ink and food colors are the easiest thing to shoot.  When you are comfortable with them, and have problems later with model paint, you'll know it's due to the paint and not you or your airbrush.
Just my opinion.
Don
Posted by Wingman_kz on Sunday, March 20, 2011 4:12 AM
A sheet of styrene is a good thing to practice on. Good thinking.  I do that sometimes too but mainly use it for color testing. I'll shoot the whole thing in a basecoat and then mask and shoot squares of different colors and lighten or darken to different degrees to see how they work together.
I mainly use a pad of watercolor paper for practice. No, it isn't plastic and it's flat but right now it's just about practicing control of the brush. And shooting on white it's easy to see how I'm controlling the overspray. I also use a small easel. I can set down in a chair and use both hands if I want. You get rusty if you don't use an airbrush everyday. It's good to take a little time to warm up and practice.
Generally I practice with the paints I use. I'm already familiar with them. And, I'm using them very thin so a little goes a long ways. Some of those craft paints will drive you nuts with tip dry and some will bead up or run. But they are cheap and may work for you.  Sometimes you can get them for under a dollar. I've intended to pick up some ink to try just never have.
The way I see it, if you already have a grasp on paint and how to deal with it and you're looking to gain more control of the brush then practice on and with whatever you like. As long as your realize the differences. But even a small, 10ml bottle of Tamiya will go a long way. I could easily turn that into 80 - 90ml and that's a lot of practice.
Tony
Posted by BaBill212 on Sunday, March 20, 2011 4:26 AM
Sarge
Practice with what you intend to use (seems to be the general concensus). This is the only  true way to wet your feet in preparation for your model. Even if you would burn through your $2.50 bottle (doubtful but depends on how much you practice).....   drop another $2.50. I would rather spend the little bit of cash than take a chance on the finished kit.
Enjoy the ride!
Posted by BaBill212 on Sunday, March 20, 2011 4:28 AM
PS
Yes, airbush cleaning is not very difficult.
Good luck with your efforts and we'll be waiting to view the final results............  All the best
Enjoy the ride!
    November 2008
Posted by plasticjunkie on Wednesday, March 23, 2011 11:13 AM
I agree that practicing with what you are going to use is best. As stated before, each paint brand has their own way of behaving and thinning issues. Just for the basics and to become familiriar with your AB you can also use craft acrylics. As  a matter of fact, I use them all the time specially on large projects that require multiple coats. They are cheap and work as good as the more expensive model paints. Recently Michael's had them on sale for .25 for each med. size bottle. I bought a ton of them. Usually they are .69 to under $1.50 depending on the brand. I  thin them with Future and add a couple of drops of W&N Flow Improver. Sprays smooth as silk and depending how much Future you add you can also control the sheen.
 GIFMaker.org_jy_Ayj_O
    November 2008
Posted by mrmike on Wednesday, March 23, 2011 2:06 PM
Another good thing to use for practice is poster board. It's a big bright surface and it's cheap, plus it holds up well to all kinds of paint.
Enjoy!
mike
    August 2006
Posted by HawkeyeHobbies on Sunday, March 27, 2011 8:40 AM
Just purchase some cheap craft acylic paint, practice on paper. You don't need to master the technique on plastic. Its more about control and application, something you can do on paper. I tell airbrush newbies to get a coloring book and use pages removed from it. Find one with airplanes and paint the plane using your airbrush. You only need a couple of colors.
Gerald "Hawkeye" Voigt
    April 2015
Posted by spadx111 on Sunday, March 27, 2011 6:12 PM
good post alot of good ideas i think i will try some .
Ron
    February 2007
Posted by mitsdude on Monday, March 28, 2011 1:48 PM
Many people, including me, spray craft paints.
However, as others have said, craft paints can be difficult to thin properly.
If you are a beginner airbrusher you certainly do not want to introduce the paint itself as a possible problem.
I second the idea to buy several bottles of the paint you are going to be using to practice with.
