Airbrush/Paint problems
    January 2011
Posted by Christian Theodotou on Sunday, March 27, 2011 5:36 PM
I was about to pre-shade my Hasegawa F-18 for the Hornet's Nest group build yesterday.  When I go to do a little test spray on the box I was using as a base, this happens...[View:/themes/fsm/utility/IMG_0257:550:0]
The paint was coming out in globs and I couldn't get a consistent stream with proper atomization of the paint.  This isn't the first time this has happened and usually I used to make it go away by adding more thinner.  After that stopped working, I thought my needle and cone were possibly bad so I replaced those.  When I tested with new parts about 2 weeks ago, no problem.  Now I'm back to this.  I use model master enamels.  When I tested I used a paint that was fairly thin already so I don't believe I added any thinner.  This flat black on the other hand needed some thinning.  I have been drawing thinner from a large can that just says paint thinner on it.  I'm think this may be the problem.  Can anyone help?  I've been reading that mineral spirits is the best solvent for MM enamels, is this correct?
Posted by Don Stauffer on Monday, March 28, 2011 8:45 AM
Yes!  Many hardware stores are selling a paint thinner that is not what we used to think of as turpentine or mineral spirits.  The best thinner for enamels is turpentine, but mineral spirits is a good second best.  Do NOT use any of this new stuff, which is milky white, not perfectly clear. It is junk. It has a lot of insoluble particles, does not thin testors well, and even effects the color of some colors.  Many hardware stores sell both turpentine or mineral spirits, the latter being a bit cheaper than the former.  The new translucent stuff is cheaper than either- I guess why it is becoming so popular.
    August 2005
Posted by Phil_H on Monday, March 28, 2011 9:27 AM
My first thought would be insufficiently thinned paint. After that, I would be looking for an improperly cleaned airbrush. If you hadn't mentioned replacing your needle and nozzle, I would be looking for a bent/burred needle or a damaged nozzle. If your paint is sufficiently thinned, I would be looking for an accumulation of dried paint inside the airbrush.
Mineral spirits should work successfully with MM enamels. It does with other brands too.
Generic "paint thinners" can vary from straight mineral spirits to the next nearest thing to lacquer thinner and your results may vary from brand to brand.
