Hi All,
Well, about 1-2 weeks ago, I posted my first post into here asking about Tamiya thinner, and I recived several posts suggesting I try Model air acrylics. I bought a couple RLM sets of paint, therr thinnner, airbrush cleaner and retarder for later use
I tried my initial sprays and I have some questions for those more expereinced. I am a new modeler and painter
I have a Pasche VL, I am using a #3 tip and needle. I did all my tests at the reccomended 1 atmosphere ( 15 lbs. on my regualtor)
1) Trial # 1, I mixed paint 1:3 with thinner ( 75 drops paint, 25 thinner ) - I was able to spray neat thin lines which I thought was good, and the "dust" spray around the lines seemed to a minimum, at least what a beginner can tell. Anyways, after painting several lines continuoulsy, the paint began to bubble in the gravity cup and the bubble grew if I kept painting. I keep the air always flowing in my brush and regualte paint, rather than tryingto get both at once. Is this bubling normal? - It appears it may interfere with paint delivery at the bottom of the cup when the paint gets low. It was not easy to "mix" the bubbles out of the paint cup either
2) Trial # 2 - 100 % paint, no thinner - essentially same results as #1, although it took longer to form bubbles
Is this to be expected? - - I thought something was wrong. Also, how much "spray" or "dust" would be cosidred normal around line work?
Thanks for your help in advance!
Joe
