Simple and silly paint questions
    April 2010
Posted by Mustang8376 on Monday, April 4, 2011 11:21 AM
Greetings everyone,
  I am looking to paint one of my models a Candy Apple Red from testors (unknown number).  I wasn't aware of the fact of needing to undercoat with either copper, silver ro gold.  Has anyone used this color before, or something similar?
   On another note, what is everyone's expereince with using acrylics?  I am noticing that they are watery, or am I making a newbie mistake?
Current build: 1/48 Monogram A-1H & AMT Jedi Starfighter.
Completed:  1/48 Monogram/Revell P-61B, 1/32 Hasegawa F6F-5, 1/48 Hasegawa F-16C, 1/48 Revell Mig-21PFM, 1/48 Revell/Monogram AH-64A, Revell/Monogram 1/48 F-14D, AMT 1/420 USS Defiant, AMT 1/650(?) USS Enterprise, 1/72 Bandai VF-1J, AMT 1/537 USS Reliant, Academy 1/35 M1-A1 Abrams, Academy 1/48 F-86F30, Linbergh's USS Gato
    June 2010
Posted by DoogsATX on Monday, April 4, 2011 11:54 AM
Reds (along with yellows) are notoriously a pain to paint. The undercoat (also white or yellow) helps the red "pop".
On the Bench: 1/32 Trumpeter P-47 | 1/32 Hasegawa Bf 109G | 1/144 Eduard MiG-21MF x2
On Deck:  1/350 HMS Dreadnought
    August 2005
Posted by Phil_H on Monday, April 4, 2011 7:00 PM
I haven't used them but I believe the "Candy" colours are transparent (ie they are not a "solid" opaque colour) and require a backing colour for the required effect. The metallic backing colour is intended to show through the transparent top coat. This gives an appearance of greater depth than a regular tinted metallic.
    April 2015
Posted by spadx111 on Monday, April 4, 2011 7:22 PM
Ditto that is correct .
Ron
Posted by Don Stauffer on Tuesday, April 5, 2011 9:34 AM
While I have used acrylics in my airbrush, I ordinarily do not like to.  The problem is, if I get distracted and do not clean the brush the minute I stop spraying, I get a clog.  I find dried acrylic much harder to clean than dried enamel when it inside airbrush.  So if you spray in airbrush with acrylic, cleaning brush well and immediately after spraying must take absolute priority over everything else.
Sometimes brushing with normal brushes can present a coverage problem.  A good primer helps with this.
Posted by ajlafleche on Wednesday, April 6, 2011 8:08 AM
All "candy" colors are translucent and require a metallic under coat to get the desired effect. Somewhere around 1964, I made the mistake of buying a can of candy color paint and spraying it directly on a model. Not a very effective paint job. Some of the Boyd colors from Modelmaster can get close to candy effects if airbrushed properly and carefully buffed out.
    August 2006
Posted by HawkeyeHobbies on Wednesday, April 6, 2011 9:01 AM
Candied colors in a can or bottle are formulated to float the transparent candy effect to the top while the metallic they contain are suppose to settle to the bottom layers. Unfortunately getting them mixed well enough and applied using the proper technique is the usual cause for them not working "as advertised". One of the best candied paint schemes I saw on a scale model car was done by first applying a silver metallic followed by several light layers of a thinned 9:1 red which was polished out after it had a couple days to cure. Then given several coats of a gloss clear...again rubbed out as needed between coats.
The coloration was deep and awesome.
Gerald "Hawkeye" Voigt
