Brush painting with Tamiyas
    April 2005
Posted by wing_nut on Thursday, April 7, 2011 10:47 AM
From some of the things I've read many of you are running off screaming into the night right about now.
Is there something that can be done to the paints to make them more suitable for brush painting?  A specific thinner or a retarder so it doe snot dry to fast? Not big open areas but parts big enough that you may need to go back over it while brushing... and I have seen the results of that... just before i went off screaming into the night.
Marc
    August 2005
Posted by Phil_H on Thursday, April 7, 2011 7:15 PM
I try to avoid brush painting large areas with Tamiya acrylics, but I've found that one part Tamiya X-20A thinner to three parts paint makes it flow that much better and retards the drying a little so you don't get as much "pull-up".
Lay down one coat, do not be tempted to even it out after it starts drying. Let it cure overnight before re-coating.
When recoating, do not linger on any given spot or it will "burn through".
    September 2010
Posted by potchip on Thursday, April 7, 2011 7:48 PM
My problem with it is precisely because Tamiya acrylics drys WAY too quickly. It literally dries on the brush seconds after exposure to air, then it dries into small grits onto the brush that's not even washable by water, having to use thinner to remove. In general flat colour is more prone to drying than their gloss range. Their semi-gloss can be treated the same as flat in terms of drying time. Most of local HS where I get my paint supplies do not have retarders.
If I must, I would thin with Tamiya thinner + water extensively and apply thin coats, and apply it multiple times to achieve eventual coverage. This obviously does not work well on small/complex surfaces due to paint pooling and is for large surfaces only. With Tamiya acrylics if you can see brush strokes, it's already starting to dry and it will not end well for you. Better it be a pool of thin paint instead.
    November 2008
Posted by iraqiwildman on Saturday, June 11, 2011 10:47 AM
Mix some of the paint with a slow-drying acrylic blending (retarted) medium on a plalette, dip your brush in a acrylic flow improver, then dip the brush into the paint. This will thin the paint to flow better and keep it from drying out so you have time to work with it.
Tim Wilding
