filtering paint
    January 2010
filtering paint
Posted by 101stAirborne on Friday, April 8, 2011 6:18 PM
Hey everyone, I got an old can of aluminum paint from my grandpa and it is a really good color for aluminum aircraft. I was experimenting with it with my airbrush and it seems that there are a lot of particles or dust or something in the paint that keeps it from making a smooth painted surface. I think I will have to filter the paint to get the particles and such out. So the question is, what should I use to filter the paint? the paint is enamel and I used lacquer thinner to thin it.
Thanks, Ryan
Models on the bench:
Too many to count!
    April 2004
Posted by Jon_a_its on Saturday, April 9, 2011 2:05 AM
Lol.... bin there done that.... any chance of putting up a pic of what you are trying to do & results so far?
Silver/Alu/metal finishes are perhaps the hardest colour of all to do convincingly.
There are loads of variables to take into account here, starting with....
OLD can from grandpa.... paint can go off, I'd use a new pot/can of paint designed for modelling.
I think Badger do small paint filters for their gravity feed cups, but first your paint needs total stirring, don't thin it yet.... I use a device similar to a coffee frother/paint stirrer/ small Dremel (on LOW speed) to stir the paint thouroughly. Don't forget to hit the off switch before removing stirrer from jar UmbrellaEmbarrassed
Filtering, fibre-free disposable coffee filters twisted into a small cone held over a paint cup/jar, OR some fine stocking mesh (panty-hose, how you get it is up to you Surprise).
Pour just enough to use in 1 go, then thin as needed before decanting to your airbrush. Metal paints tend to settle out very quickly esp, when thinned for spraying so lots of agitation is needed.
Then there's the finish of the target: needs to be smooth smooth smooth for natural metal finishes, esp on aircraft .... Alclad say spray over a seni-gloss black undercoat.
Then there is environment: dust is your enemy, as is humidity: spraying in the yard or garage might not be the best place, a dry shower room is almost ideal (just don't let your N&D catch you...), then cover your wet model with a large tupperware (or similar) box, slightly propped up to keep dust off but allow air circulation.
East Mids Model Club 32nd Annual Show 2nd April 2023
 http://www.eastmidsmodelclub.co.uk/
Don't feed the CM!
    January 2010
Posted by 101stAirborne on Saturday, April 9, 2011 9:23 AM
Thanks for the help! There certainly is a lot to take in to consideration! I will do some more experimenting and let you know the results.
Too many to count!
Posted by Don Stauffer on Saturday, April 9, 2011 9:33 AM
One common method of filtering paint is to run it through a fine thread cloth.
    September 2010
Posted by Marine Sniper on Monday, April 11, 2011 6:28 PM
Don Stauffer
A piece of old nylon stocking works great and is cheap. Yes
